1995 timing cover mod to work with newer HPOP without drainback issues
I thought I would post this for those that are interested.
This mod is for those of us with 1994 and 1995 strokes that want to install a new SD HPOP. Most of us that have done this have experienced HPOP reservoir drain back issues that result in hard starts after 2 or more days. One way to fix this is to modfiy the existing 1994 or 1995 timing cover to work with a new HPOP reservoir from a 1996 or newer engine.
Re: 1995 timing cover mod to work with newer HPOP without drainback issues
radar--when you drill thru--shavings inside engine????? know how to stop it--hook up vacuum cleaner to engine--with the pressure side of the vacuum cleaner--can do this with a lot of them--wont have tons of pressure--but when drill thru--will blow chips out the hole--be sure to wear glasses!!!!!!!!!!! hook it to the oil fill hole--or have someone hold the hose over that spot when just about to punch thru-----
Yep......And also get yerself a can of old fashioned aerosol shaving cream.
Once you have your rags inplace, spray in a nice layer of shaving cream....The foam will catch all the metal shavings and trap them like glue....it is really easy if you first tie some strong thread or thin string to each rag and use it to pull the rags up thru the shaving cream as you remove them.
Use the shaving cream trick if you ever need to rethread a spark plug hole on gas engine. Just make sure the piston is all the way down, then fill the cylinder with shaving cream...when you are thru tapping the hole, just rotate the engine by hand and the piston will push all the foam and metal fragments up and out the spark plug hole...Any residual cream left in the cylinder is rendered harmless with a squirt of WD40 or similar.
95 F-350 DRW extended cab Dixie Custom, 180K troublefree miles, straight pipes, no other mods....Yet.
great article with fantastic pictures, glad someone found a cheaper solution than I had. This is why thsi forum works so well.
__________________ Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now pictures
2004 Dodge 3500 twin turbo 525hp rocket
I will try to update any errors I find and add part numbers if I can as time goes by.
Special thanks to Rich (95F450SD) who was behind the original idea.
Good luck everyone!
[img]/ubbthreads/images/graemlins/ooo.gif[/img]Great---THANKS--on My GOTTA DO list--- :warmsmile
95 F350 SC-8ft. box, PSD-230000+, 4x2, 5sp,5531 Spicer aux.,Baby Swamps, BD downpipe, Summit racing 4 " bullet muffler-exit ahead of rear tire, ATS air to air-a mistake?,MAP sensor press reg mod, DIY TYMAR, Bully Dog 4 pos.Flipchip, pillar gauges ,3.55s- shimmed FRR =65., HPX, Swamped, South Bend SMFW and clutch,LUK PP.,Gutted EPV, AIC-thanks Patrick,DIY mod IDM, white face gauges-PYRO IN DOWNPIPE
DESTROY AMERICA-JOIN AN ENVIRONMENTAL GROUP
Looks great, one question though (for now). Would it be feasible to tap for a 1/8 NPT pipe plug instead of using a self-tapping screw? That should seal much better without silicone sealant?
Okay, two questions.... How much injector would this SD pump handle? Would it let me run a 160 cc on a fairly aggressive chip without throwing a CEL??
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
I think that the 1/8 NTP plug would work great. I just did not do it because I did not think of it. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Regarding the SD HPOP, it is a crap shoot because some HPOP's are better than others of the same part number. Depends on the internal clearances I guess. BUT.. in general, I have heard that -most- people with SD HPOP's are running just fine without CEL's, myself included. I have held the pedal to the metal up a long grade in the extreme setting running 35+ PSI boost for over 20 seconds without any CEL and my injectors are 170cc's.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Awesome! Maybe with next year's tax refund...
Thanks!
I've plugged that hole in the timing cover and still have the drain back problem only now it's getting worse and I'm having a really hard time just starting it. I've checked every thing I can and every thing I've read on here and can't find any thing wrong. It's almost like the HPO res. isn't filling at all.
94 F-350 reg cab 4x4 5 spd, autometer boost and pyro, quick connect HPO guage, Swamps Gen3 HPOP, 355cc injectors, H2e and S400 turbos, 5 inch exhaust all the way w single stack, 99.5 3" intake plenums, DP tuner w Jodys tunes, Tymar air filter, South Bend dual disc clutch, electric fuel pump, rebuilt bottom end, bored, balanced, comp cam 910 valve springs, head studs, front cover machiened to match 96+, 3 angle valve job, fire rings, HPX hose, drop rear bumper w cusion hitch and 4" reverse lights, sun visor, nerf bars
'94 F350 reg cab 4x4 5 spd dually, western hauler bed, autometer boost and pyro, TS 6 position chip, 3 inch downpipe to 5 inch stacks, IDM mod, shimed FPR, visor, diamond plate front bumper, 180cc injectors, '99 E350 turbo, 3" plenums, South Bend clutch
I'm using the resivor that is part of the Gen 3 pump
Hey, have you guys talked to Joey at Terminator? He is now turning the *15 pumps into *17 without having the drain back problem. He can put the *17 pump into the *15 case. I just wonder if any of you knew this or not??
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
