1995 timing cover mod to work with newer HPOP without drainback issues - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 01-23-2008, 10:57 PM   #16 (permalink)
how do you tell the difference? I keep reading all these different things on here and I don't follow any of it at all.
94 F-350 reg cab 4x4 5 spd, autometer boost and pyro, quick connect HPO guage, Swamps Gen3 HPOP, 355cc injectors, H2e and S400 turbos, 5 inch exhaust all the way w single stack, 99.5 3" intake plenums, DP tuner w Jodys tunes, Tymar air filter, South Bend dual disc clutch, electric fuel pump, rebuilt bottom end, bored, balanced, comp cam 910 valve springs, head studs, front cover machiened to match 96+, 3 angle valve job, fire rings, HPX hose, drop rear bumper w cusion hitch and 4" reverse lights, sun visor, nerf bars
'94 F350 reg cab 4x4 5 spd dually, western hauler bed, autometer boost and pyro, TS 6 position chip, 3 inch downpipe to 5 inch stacks, IDM mod, shimed FPR, visor, diamond plate front bumper, 180cc injectors, '99 E350 turbo, 3" plenums, South Bend clutch
bigal6x6 is offline
Old 01-24-2008, 05:53 PM   #17 (permalink)
My Photos: (6)
Look here: DSCF2022
The bottom is the 96 and up one that you want. Note the extra hole in the bottom of the housing. That is the 'standpipe' that you are drilling the hole in the cover to match up with.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
