Take some time and read alot of posts here on what else you need to do to run any bigger inj.
Short answer is lots of $$$
Stage 3's..$12k
Stage 2's $12k
Stage 1's..$4k...if your trans lasts
Cary
If you don't make any other mods to go along with the injectors, than I recommend Swamps Diesel Baby Swamp injectors. They will flow more when you add minor mods. Good luck.
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps * http://community.webshots.com/user/ammayernick
What is the best brand of injectors to get for my 1996 F-250 powerstroke with A/T? I would also like to know if I should get stage 2 or stage 3.
Welcome to TDS.....
Kinda depends on what you want to do to your ride? tow, street race, pull or Daily driver, you must also consider support mods as well....Down pipe, gauges, intake and exhaust and program files (chip).....
I have been very happy with the mods in my sig and have many many miles on my B Swamp's injectors.....If I did it again...hmm well would probably go with Stage 2 as you can tune your chip for less HP while you continue to add supporting mods. Try to read lots here and go for a ride with a buddy who has done some mods....
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler. http://community.webshots.com/user/jcart44
i like my baby swamps may upgrade to a small hybrid soon
95 f-250 psd 3in dp 4in ate the cat straight pipe 1.0 turbine housing shimed fpr diy tymar auto meter gauges idm mod southbend con oef baby swamps swamps tunes 6.0 IC
