Question of why I am keeping the catalytic converter?
Here is my lawful answer...
Isn't it the law to have one on your vehicle? If you don't how do you get away with it? Is there a fine for not having one?
I removed the stock cooler located in front of the radiator and used the supplied hardware to install the Tru Cool in the existing holes in the radiator/grill support. Don't forget to top off the transmission fluid as the Tru Cool holds more fluid than the stock cooler.
1997 F-250 XLT, 7.3 PSD, 4WD, Super Cab, LWB, Warn manual hubs, 203 thermostat, 4.10 LSD, Jasper remanufactured E40D at 138,000, Factory Tech valve body, Stage II injectors, AFE intake, Bilsteins, Bully Dog 4-Position chip, 3" downpipe, 4" MagnaFlow exhaust, AutoMeter guages, 265's on stock wheels, Tru-Cool 4590.
Do they smog check your truck and look for factory installed parts..if not it fell off [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
cary
What about a bypass valve? The 4R100's have them stock... but not E4OD from what I can gather....Do we need a bypass valve for temps to be more stable? The 4739 max from Tru-cool has one available built in for $140 from the dieselsite but I don't want to spend the money if I don't have to..
No test.....mod away! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Cary
I've made all my updgrades, increased flow, transmission cooler, power chip, guages and now I have a torque convertor code trip when I am pulling my 30' camper. When I am not pulling then the transmission shifts kind of hard. What are my choices out there? Earlier it was stated, "Invest heavily in good torque converter - it'll save you later. Also add shift kit for stronger shifts which reduce temp's." Any advice in this area? Any links? Thanks Tom
