My factory shop manual says my thermostat is a 205 (starts to open at 205, fully open at 220). I haven't found one yet. Motorcraft website gives a part number for 190 degree. Where could i find the 205 one?
-97 F250 HD PSD SC LB AT 4x4, 102K, stock
plans: some gauges, tymar-type intake, mild chip
I dont want to be a PITA, but the dieselsite thermostat is a 203, and I just feel like i should be able to find a long stem 205, especially since thats what the factory says it is supposed to have.
Thanks.
You can feel however you want but it ain't gonna happen. Your factory shop manual also says the coolant flows from the water pump to the heater core and from the heater core to the head, what are you gonna do about that?
The stant long stem replacement that I put in last week said it was a 195 on the box but didn't start opening till after 200* when checked in a pot with a calibrated thermometer. I would guess that the difference between a 203 and a 205 is negligible in the grand scheme of things if youre interested in buying a $30 thermostat.
Bob
1996 F-250 XL Powerstroke 7.3 Extended Cab Long Bed. Stock for now. 280,000 miles and counting
[img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] You noticed that too? Ive found several things in the Helms manual that are bass ackward.
Change the water pump and t-stat at the same time.... then do you not have the option of using the short-stem pump and readily available 203-205* stat?
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s, D60 swap, straight pipe, turned up fuel screw
Oooh, now my feelings are hurt---NOT!, heh
Anyway, he's right. Ordered the 203 from dieselsite allong with the housing. whatever.
The intl 1822815c1 someone had a picture of in the 203 thread mentioned above, is not sold (prolly never was) by Intl dealers, it was made for Ford as a "Ford part" for OEM installations only. Intl dealers don't even know what teh degrees were.
The rest (motorcraft, stant, wahler, napa...)are lower degrees or short stem (as you know...)
-97 F250 HD PSD 4x4 SC LB AT 102K, stock
It's everywhere. There are some bolts with metric heads and sae threads [img]/ubbthreads/images/graemlins/tongue.gif[/img]. I wouldn't worry about 203 vs. 205 if find a 203 that will fit. If you tested 50 in water you would probably find some open higher and some lower than 203-205.
__________________ TheRacer XBuilt E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Dieseland nitrous!
Family owned & sponsored by : FloridaNorth
