Old 03-22-2006, 11:43 AM   #1 (permalink)
255/85/16 All Season Tires
Does anyone make a 255/85/16 all season tire? The reason I am asking is I can't seem to find any [img]/ubbthreads/images/graemlins/shrug.gif[/img] I am trying to find a replacement all season tires with a little more height but not necessarily a lot more width than the stock 235/85/16 tires.
Griz
95 F250, 4X4, E4OD, 4.10, Hypermax DP and Tymar 4" Exhaust System, Tymar Air & Coolant Filters and HPX Kit, Tymar fuel fill mod, External Transmission Filter, Schaeffer's ATF. Add-a-leaf, Redline Differential gear oil and Redline ATF in Transfer Case. OilGuard By-pass oil filter. Schaeffer's 5W-40 in the engine. A-Pillar...Autometer Boost, Pyrometer and Trans. Temp. Gages, Under dash...Oil Pressure and Water Temperature gages, 1705 Superchip Tuner, Stancor GPR, Factory Tech Valve Body, Evans Waterless Coolant, Two 4590 Tru-Cool Transmission Cooler in series, Explorer Overhead Console, Diesel Turbo Lifesaver, Tymar Fuel Filler Mod.
Griz is offline
Old 03-22-2006, 12:24 PM   #2 (permalink)
My Photos: (32)
Re: 255/85/16 All Season Tires
Dale I. runs them on his truck. Ask him, he'll tell ya! I think he has BFG All-Terrains? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
Old 03-22-2006, 12:40 PM   #3 (permalink)
My Photos: (5)
Here's what I got when I searched tirerack.com.... these are both load range D, and not cheap.
Link Here
On Edit: Reposted link to eliminate horizontal page scrolling necessity.
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 03-22-2006, 12:43 PM   #4 (permalink)
My Photos: (5)
here's a dealer selling kelly's for $320 for a set of four:
again, load range D
Click Here
On Edit: Reposted link to eliminate the need to scroll horizontally to read the page.
Old 03-22-2006, 12:47 PM   #5 (permalink)
timberjack's Avatar
My Photos: (12)
BFG doesn't make that size in all terrain, maybe they did, but they don't seem to now.
I've got that size in the mud terrain flavor on both the psd's i've got. Very happy with them, have about 20k miles on the 95's tires so far, and pleased with the wear. I estimate there should be another 25-30k miles in them at least.
Griz, check out tirerack.com. I believe Dunlop, Goodyear, Cooper and Kelly, and maybe others make them in that size too. There should be something in the right tread pattern for what you want.
1995 F-250 XL 4x4 PSD - Work and snowplow rig
1996 F250 XLT 4X4 Supercab PSD - Camper hauler
Webshots of some of the riggin' and scenery
timberjack is offline
Old 03-22-2006, 01:46 PM   #6 (permalink)
nebraska tire has em for cheap...
by the way, that's the size I was thinking of going to. I like keeping my tires at 65psi cause I hate raising and lowering the pressure depending on load weight vs empty weight so I leave them up and the centers wear out (crown) on my 285/75/16s. That's why I'm gonna go with a skinnier tire.
'97 F350 PSD E4OD CC 4x4
265/75/16, BB shim=73psi, Open Element, 10K with switch on dash, IDM mod, 30K Hayden tranny cooler, 3" downpipe, 4" straight pipe, the usual gauges, Bullydog 6 position chip. Biodiesel as much as possible.
Tankota is offline
Old 03-22-2006, 01:50 PM   #7 (permalink)
Do a search for Wild Country TXR, fairly good traction but not real loud on the highway
1997 F-350 CC lb XLT 4X4 5spd 4:10,s manual hubs new 255/85/16 Wild Country TXR shoes Westin steps Bilstein shocks Velvet Rides Phantom boost & pyrometer in A pillar water shut-off new fan clutch Tymar intake new IPR new ICP Tymar 4" turbo back exhaust no EBPV no kitty Diesel Power 3 pos flip chip new Valeo clutch @ 109750 Redline MTL & D4 in the bottom BDP Stage 1's valve cover gasgets & glow plugs @ 110650 = pushing Curtis Sno-Pro 3000 & pulling 28' Sierra 5th wheel camper & 18' Sylvan Sportmaster hooked behind camper
6.0 IC next
1994 Ford Ranger (off-road project)
God bless the American Soldier,paying the price for my freedom
Favorite Quote:
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independence. When Firearms go, all go's. We need them every hour!"
US President GEORGE WASHINGTON
BlueDeuce is offline
Old 03-22-2006, 02:45 PM   #8 (permalink)
I run the Cooper Discoverer ST , I like'em.
-Shanon
'96 4X4 CC/ShortBed F-250, Hypermax Downpipe, Four" exhaust, ISSPRO EV Gauges in Rockin S Pod, Bilsteins, Hx Crossover, Open Air Element, Bill's chip (now with TWildman burns), BTS trans, <font color="red">Baby Swamps</font>, Gentex mirror with temp/compass, and Dana 60. My Photos
BellyHead is offline
Old 03-22-2006, 02:47 PM   #9 (permalink)
Tim...I know Dale runs them but I don't 'believe' BFG makes that size any more in the All Terrain. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Griz
Griz is offline
Old 03-22-2006, 03:38 PM   #10 (permalink)
KRP
What's the difference between an "all-season" and an "all-terrain" tire? I've got 255/85/16 Wild Country XTXs on my truck, but I think they are labeled as an "all-terrain" tire. Les Schwab sells several different tires in this size.
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
KRP is offline
Old 03-22-2006, 05:17 PM   #11 (permalink)
I'd say generally the all season is more of a street tire and the all terrain is a little bit more aggressive...nothing like a mud tire though. For my driving conditions I prefer something in between all season and all terrain.
Tankota is offline
Old 03-22-2006, 07:28 PM   #12 (permalink)
I wouldn't mind a good all terrain tire...I just don't want a real aggressive tread...don't need it for what I do [img]/ubbthreads/images/graemlins/smile.gif[/img] Besides I want to hear the turbo not the tires [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Griz
Griz is offline
Old 03-22-2006, 08:31 PM   #13 (permalink)
DaveBey's Avatar
My Photos: (212)
Send a message via AIM to DaveBey Send a message via Yahoo to DaveBey
Griz -- I've got the 255/85R16 tires on my truck. I ended up with the Wild Country XTX which I consider an all-season tire. If you're lookin' for an all-terrain tire, I'd look at the Wild Country SXT.
If you don't have a Les Schwab near you (Florida is like 1,800 miles away from one), look for a dealer that caries the Multi-Mile tire line.
Cheers from Orlando, FL! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dave
1996 F-350 XLT CC SRW 4x4 with plenty o' Redneck Bling: APCM●BTS-E4OD●4L10●MADDOG injectors●Hypermax H2E, intercooler, & exhaust●TYMAR intake & HPX●TSM disc brakes●Hydro-Boost●International water pump●215 amp generator●CCV re-route●285/75R16 Wild Country XTX tires●Centramatics●Denon DCR-830RD & DCH-520 203,000 happy miles
DZLJIM 3:16
~~NTxPSA - Hold my beer and watch this.~~
DaveBey is offline
Old 03-22-2006, 09:30 PM   #14 (permalink)
kfjensen's Avatar
Im with Belly, I just got them last September ( Thread ) and used them quite a bit in snow/ice. They performed very well, I was very pleased with them, but they are a 265 not 255, still though I was amazed at how good they handled on the ice.
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 03-22-2006, 11:12 PM   #15 (permalink)
I had the XTX before I went to the TXR , XTX had no traction on snow &amp; ice and would hydroplane in a hard rain, Les.
6.0 IC next
Favorite Quote:
