Old 12-23-2005, 10:35 PM   #1 (permalink)
2nd gear burnout power
I was just wondering if any of you 5 spd guys have your truck modded enough to burn out in second gear (no power brake). I don't want to go tearing my truck up, but that is the kind of power I am looking for in my 96 and jsut wondering how much I have to mod to get to that.
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 135k mi.
psu927 is offline
Old 12-23-2005, 10:36 PM   #2 (permalink)
My Photos: (9)
Re: 2nd gear burnout power
Most of the time my BTS auto will spin when shifting into 2nd gear.
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
SLAPS Treasurer
Member of FOKISD
<font color="red"> #5 </font>
Truck pics at http://community.webshots.com/user/ytee1100
ytee is offline
Old 12-23-2005, 11:03 PM   #3 (permalink)
johndeerebones's Avatar
My truck will lay some pretty good rubber with the mods I have. Only do it when I'm trying to get outta someones way or something. Without trac bars or something the wheel hop is probably bad enough to rip out your tranny. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Burnouts ain't cool though, hookin up and gettin gone real quick is what gets my adrenaline flowin. [img]/ubbthreads/images/graemlins/eek.gif[/img]
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 12-23-2005, 11:55 PM   #4 (permalink)
My Photos: (5)
do all my burnouts in 2nd gear, pull through the waterbox, put in 2nd, smash brake pedal real hard, set line lock, pop the throttle and ease it back to about 6500, release line lock when it starts to grab get off the loud pedal....oops, wrong forum, you meant the truck.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 12-24-2005, 12:36 AM   #5 (permalink)
i wish there was a way to measure wheel hop in inches...i've got 4.10 open diff with 33's. i have never laid rubber but have got a couple inches of air under the rear tires trying. [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/ooo.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
RYAN
GAUGES, INTAKE, EXHUAST, SBC CLUTCH, CHIP, BDP INJECTORS, BILSTEINS, BUSHINGS...AND A WHOLE LOT MORE..
pics
B99 BIO DIESEL SUPPORTING AMERICAS FARMERS.
US NAVY
looking for an ext cab 4x4 short bed DURAMAX!!! keeping the obs of course.
1997PSD4ME is offline
Old 12-24-2005, 09:37 AM   #6 (permalink)
like I said, it's not really the burnout power I want, it's the "get up and go" that I want.
psu927 is offline
Old 12-24-2005, 10:05 AM   #7 (permalink)
Mine always just wiggles around when it's pulling hard in the lower gears up through 3 or so, but doesn't break loose on a smooth dry road. But it's just the 37's, cause it flat murders the little stockers lol.
So I would say that 400hp would be a good starting point for hosing stock tires through second.
Charlie
CharlieII is offline
Old 12-24-2005, 01:35 PM   #8 (permalink)
Mine will lite em up in second gear with no breaks. There is a little clutch abuse happening though, cant do it from a rolling start.
1997 Powerstroke F250 4x4, Swamps hybrid 250's,3 position chip,Hypermax down pipe, gutted ebpv,Isspro pyro and boost,Tymar intake, South Bend con-o-fe,DIY 5" turnout stacks,cheessy stick on fiberglass hood scoops, cracked windshield, and various wiskey bumps
<font color="red">MY PICTURES</font>
Nathan79 is offline
Old 12-25-2005, 04:43 PM   #9 (permalink)
i can do it in second gear but its mostly contributed to the gears i have.
'95 f250 5spd powerstroke, 4" lift, 315 BFG mud terrains. diy intake , 3" downpipe. 4" exhaust
'84 f250 6.9l, c6 trans
Pwrstrokin19 is offline
Old 12-25-2005, 05:51 PM   #10 (permalink)
My Photos: (10)
i dont do a whole lot of burnouts, but with 410s i can tach it up alittle and dump it and it set and spin in 2nd gear.
Ben
97 F-350, Red with white stripe, reg cab, xlt, 4x4, 5spd. 4:10s, Tymar intake, HPX, 3x4" downpipe, 5" exhaust, autometer gauges, 6.0 intercooler, beans stage 1s, Tony Wildman chip. 210k miles
341/785- 5/19/07
sold..97 F-350, red, reg cab, xlt, 4x4, 5spd, 3:55's, tymar intake, autometer gauges, south bend OFE, Tymar intake, 3x4" downpipe, 5" exhaust, HPX, gutted EPBV, Tony Wildman chip, 180cc injectors. 176k when sold
http://photos.thedieselstop.com/show...hp?photo=29440
sold..96 F-250, midnight blue, reg cab, xlt, 4x4, 5spd 4:10's. hypermax dp, gutted EPBV, 4" straight exhaust, tymar intake. 189k when sold
Copenhagen...S'nuff said
bigjohnson is offline
Old 12-26-2005, 11:01 PM   #11 (permalink)
If I powerbrake a bit, I can spin both tires thru overdrive. Oops, you said 5 speed. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
<font color="red">Trucks </font>
1997 F350 CC SRW 4x4, BTS E40D, 4.10 LS,TDEO, Banks Intercooler, Maddog Stage-2's, Stealth dual-HPOP, W.O.P Quickspool, 3" Intakes, 4"downpipe, Headstuds, H-max rev kit, Aeromotive fuel pump. Tymar Intake, JoeServo IDM, Ultralite gauges, Silver-reverse glow guages, Jody Tipton Chip, Magnaflow muffler, Reunel Rear Bumper, Evans Coolant, Best 1/4 mile 14.58
1999 f-350 SRW CC 4X4 AUTO 3.73LS, BTS Tranny, Code W Front springs, Elelbrock IAS shocks, AIS air cleaner, Bill's 2 position chip, DI 4" Aluminized Dynamax exhaust with 3.5" downpipe, Rickson 19.5" wheels,Michelin XDE-MS LR-H(16ply), Hellwig hd sway bars front & rear, 2 layers of Brown Bread, Excursion sound pads at firewall, pillar pod gauges,Tekonsha Prodigy. Cowl Inducted Hood, APC Projector headlamps, APC corner lamps, Carbon fiber Tailamps, Body color grille, cowl panels, door handles, tailgate handle.
Rbob is offline
Old 12-27-2005, 02:45 PM   #12 (permalink)
The mods in my sig will burn out in second, but the axle hop is TERRIBLE. It would definately DESTROY many things if you let it go very long.
1996 F350 XL, PSD, CC, LB, SRW, Green/White, 4x4, 4L10, ZF5, LUK clutch & flywheel, 295/75/16 BFG AT on 16 x 8 Centerlines, Bill's Race chip, gutted EBPV, Ceramic coated Hypermax downpipe, Tymar 4" exhaust w/Donaldson muffler, Tymar Intake, Tymar boost pop-off valve, Tymar HX hose, Tymar coolant filter, JD Coolant eye, AC & fuel tank mods, Autometer Pyrometer & Boost gauges in pillar pod, Warn Premium hubs, Powerslot rotors, Smittybilt nerfbars, add-a-leaf & poly bushings, Bilstein shocks, Drawtite front receiver, Optima red tops, 130W Stainless KC Daylighters, stainless Ventshades, Eclipse CD player, MB Quart speakers, JL sub, Phoenix Gold amps, Viper alarm, Cobra CB, 2001 Honda CR250, 400EX & ATC 70 in the bed, not much more to come...
1996CC is offline
Old 12-27-2005, 07:26 PM   #13 (permalink)
put traction bars it won't hop any more
1996 F350 C/Cab,7.3L PSD/M Burgundy/15000 lb warn winch/Tymar filter/4"exhaust/no kitty/pre turbo pyro/boost guage/BD4banks chip/no back seat, custom tool box instead/110 4000 watt inverter/on board air/200 amp alternator/4"lift/ Royal purple oil rear 75/140,syncromax in tranney/RottelaT 15/40 in engine with Durolube/Evens npt+ watterless antifreze/luk clutch solid flywheel/home made AIC/power stearing line mod/home made traction bars,
shendoa is offline
Old 12-28-2005, 01:48 PM   #14 (permalink)
They have there downfalls as well, not really on topic here.
1996CC is offline
