2WD ZF5 to 4WD ZF5 Conversion? - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 01-23-2007, 07:27 AM Thread Starter
I am making the 96 PSD in my sig into a 4x4. I found the donor vehicle.
1992 F-350, SRW, 7.3 liter diesel, with a zf-5 tranny. The transmission has some serious noise.
Will the main shaft from the 1992 ZF5 4x4 transmission fit my 1996 2x4 ZF5 transmission?
If not does anyone know of a source to purchase the main shaft for my 2WD ZF5?
Found it in another post by skeen450:
I can answer the 5 speed question, as I looked into a similiar setup myself.
The zf5 manual trans will have to have a new main shaft and a new tail housing. Both cost close to 300 bucks. Then the labor to pull the entire trans apart to install. I was quoted about 600 bucks for a shop to do it.
This place has the parts, just look thru it for what you need.
http://www.tbtrans.com/transmission_...rd_truck_parts
After you got that done, the transfer case from the auto will bolt right up.
95 PSD crew cab LWB 5 speed 276k miles
redneckerson is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Gear in this thread - Powered by O'Reilly Auto Parts
