As a couple of my previous posts have said I am rebuilding a D60 for the front of my truck. I currently have 3.55 gears with 33" tires. I would like to have some 3.73 gears but was told my drivetrain warehouse that they do not make them for a d60 reverse cut. So I am stuck between keeping the 3.55 or getting 4:10. Later I plan to go to 35" tires. I like the 3.55 but don't know how they would do with 35" tires being that I pull every know and then and when I do it is a pretty heavy load. I curently get bewtween 16 and 18 mpg now unloaded. I was just wondering how bad the 4.10's would hurt my fuel mileage. Let me hear what you guys think about the different gear ratios and tire size combos. Thanks
Justin
1983 F-250 2wd Diesel 4 spd man with 3in Body.
1996 F-250 extended cab 4wd MLE) with 230k miles,4" TC Lift, 79'D60, full spool, Warn hubs, 3.55, 5 speed, 6 pos TS chip, 3" downpipe, straight piped, 5" tip, Open element home made setup, Luk, autometer boost and pyro, cali. fpr kit, ranchhand front, 35" Cooper ST 's 2005 F350 emblems, big dent in side of bed [img]/ubbthreads/images/graemlins/frown.gif[/img]
Next: 4"or 5" Exhaust, injectors, traction bars
I don't know, but I'm glad I misunderstood your question. I thought you were now getting 4.10mpg and were getting 3.55mpg. Glad that's not the case, but if it were I guess 4.10 would be a 20% "better" number than 3.55. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Ron Hansen, 1997 F350CC, 4x4, PSD 110,000 miles all stock with stupid auto transmission unfortunately. 1993 Ford E350 Club Wagon 7.5L 11,000 miles, 1978 Kawasaki KZ650 motorcycle with 167,000 miles!
My 88' has 3.55s and my 97' has 4.10s. I prefere the 3.55s. You can always run the small tires when you know you are going to pull heavy and run the 35s the rest of the time.
97' F-350 4x4 crewcab powerstroke, 5-spd, luk clutch, 4.10, big exhaust, homemade Tymar intake, bb in fuel regulator, front leveling spring, 35" BFGs,
64' F-350 4x4 Dana 60, 14 bolt, 390cid, 38.5 swampers, looking for rockwells
69' charger
68' camaro ss
72' GMC 4x4, 4" lift, dana 60, 14 bolt, 35" BFGs
I never thought about that one I guess I will have to hang on to those stock aluminum wheels plus I already have two brand new 285 70 mounted on two of them. Don't really want to change the wheels out every time I pull something but I am pulling something a long distance it would be a good idea.
Justin
i have 4.10 gears and 35" tires (4x4) and get between 14 and 16 (in town)depending on how i drive,on the highway empty i would say 18 , i didn't notice a difference when i went from 285's to the 35's if there was it wasn't much
1996 f350 srw 4x4 3" downpipe 5" exhaust,tymar intake (real one), ts performance 6 position chip,e40d, 112k miles,35"tires,gutted ebpv, egt, boost, trans temp gauges, aftermarket trans cooler
It seems like you would be around your goal of 3.73's with the 35's and 4.10's. Not sure, but you can always pull up a gear calculator and do the math. As for not making reverse cut gears for the D60? That is horsecrap. That is the most popular axle available, next to a D44, you can get them, check out Randy's Ring and Pinion, or any other off road shop. They are out there. Scotty
I've got 35" tires and a 4.10 rear end. I get up to 20mpg on the freeway at 70mph. I would think that 3.55's and 35" tires would make it awfully long legged for towing. Swapping out the wheels when you tow is a great idea, should you choose to go with the 3.55's.
__________________ Quadzilla
'95 F-350XLT Crew Cab SRW 4X4 PSD, 35X12.50X16.5's, LS 4.10's, Air bags front and rear, PS 2000 propane, TYMAR intake, 1.0AR turbine housing, gutted EBPV, downpipe, 5" exhaust system, DP chip, Autometer gauges, Fumoto valve, Tru-Cool, HX mod, Tricumulator springs, Sonnax valve, 4R100 pan,
Magnefine tranny filter, reverse shackle kit, Big_Fig power pedal,
(Thank God for a wife that likes big trucks.) Pictures I'm not affilitated with the vendor "Quadzilla" in any way.
who ever you spoke with about the lack of 3.73's is a moron, and i wouldnt give him any money. Try here
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains Try the SEARCH Button Because It's Probably already been asked
Re: 3.55 mpg vs 4.10 mpg with 33" or 35" tires *DELETED*
Post deleted by Dusten
17x9 Pro Comp 7189
Drivetrain warehouse told me that there were 3.73's for the d50 but not for d60.
I am kind of leaning toward sticking with the 3.55's for now they work pretty good for me know with 33's but not to sure about them with 35's. The main reason I am insterested in the 4.10's is because it is only $200 more for front and rear with everthing needed to install rather than just installing 3.55's in front with everything needed to install. Just don't want to take a big chunck out of my fuel milage with 4:10's due to fuel prices now days. The 4.10's with 35's would bring me about back to where my actual gear ratio is now.
I have been using the crap out of this gear calcualtor all day.
Justin
Thanks but the site says that the gear will work in a 1980-1998 my d60 is a 1979. I called them but they are closed I will try again tommorrow. Before I get a bunch of posts that it won't work in my truck. It will work if you move the spring perches and get different tie rods.
Justin
Yeah, I was thinking that I was told not too long ago that 4.10 gears with 35" tires would hang you right in the area of 3.73. Don't remember who told me that, but I hope it helps you out!
1996 F250 4x4 5sp shortbox, ats intercooler, DIY Tymar, 3" dp, Dual 5" stacks, South Bend Con-O clutch and SMFW. BDP Stage 1's up and running!!! my truck
TS 6 pos. chip-High idle, Economy, Tow, Jody Tipton Hot (75 hp), Diesel Power Extreme, and TWildman's "Move it or lose it" Extreme
"A man can always stand a little bit more horsepower" - Chris Ledoux
Thats what I thought to but when it said 1980-1998 that got me thinkin why wouldn't they work no other web site said anything about that. I believe I am going to stick with the 3.55's. And if I don't like the 3.55's with 35's which I won't get for a while since I already have good tread on my 33's. I can always save up and change them out later. And as recommended earlier If I really need to tow something a long distance through the hills I can put the factory wheels and tires on and hit the road. Thanks for all the help you guys are great.
Justin
