Old 08-27-2008, 01:19 PM   #1 (permalink)
harleywgcple's Avatar
3" Downpipe
Got my 3" diamond eye down pipe in for my 97 f350. can anyone tell me how much of a headache im gonna have. they said my have to bend lip 1/2", but my lip is covered with a heat shield pan.
Do you need to remove this pan or leave it in and pray?
1997 F350 DRW Centurim Conversion 5 Speed 4.10 pyroguage boost guage 3
" daimond eye downpipe tymar intake
gears.http://www.flickr.com/photos/22748801@N07/
harleywgcple is offline
Old 08-27-2008, 01:24 PM   #2 (permalink)
tbeck's Avatar
I trimmed the firewall lip right thru the heat shield pan with a sawz-all. Squish it up with a porta-power. Make PLENTY of room; its a bugger if its a bit too tight and you have to go back and do it again!!
'94 1/2 F250 4x4, SuperCab XLT, 5 spd, SMF w/ Valaeo clutch, 4.10 (syn. lube), 5w40 Rotella T Syn, manual hubs, Flip over Gooseneck hitch, authentic Tymar intake, 4" AFE exhaust, FRP mod., Isspro boost/pyro,digital thermometer, homebuilt exhaust brake, 153K
tbeck is offline
Old 08-27-2008, 01:28 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I used a old school digging bar. Put it on the head and bent away. Mine seemed to have more room than others, but maybe that bar did a better job than I thought?
Go more than you think you have to.
MarkEkberg is offline
Old 08-27-2008, 01:32 PM   #4 (permalink)
did you use diamond eye or MBRP downpipe?
Old 08-27-2008, 04:08 PM   #5 (permalink)
chris u's Avatar
I put a mbrp pipe on mine just left the heat shield on and bent like everyone says to much is better.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline
Old 08-27-2008, 10:39 PM   #6 (permalink)
Like chris u said, but don't let the heat shield touch the dp. mine was touching and it was loud inside the cab, I cut all the loose shielding out from the cutting and prying and then I put heat wrap on the dp. A good pry bar and a block of wood does wonders to bend the pinch weld.
1996 F-350,CC,LB, Rebuilt Tranny,Billet Trq conv,shift kit, AFE Stage 2 intake, 3' dp, 4''Diamondeye exh with flow through muffler, 35"BFG's,no lift,new engine wiring harness,new fuel heater(dealer fixed due to a short before I found this site,knowing what I know now I would have just unplugged it),new glow plugs at about 145,000 mi,balljoints,bearings,rotors,all new steering linkage,GPR,powersteering pump,steering wheel bearings,IDM mod,rebuilt turbo and gutted EBPV and pedestal,just over 175,000 mi,
Big Jeremy is offline
