Old 07-14-2008, 08:13 PM   #1 (permalink)
3" MBRP downpipe
Just installed my downpipe on my 97 and I got the two pieces in snugly. I started up the truck had no leaks, but every once in awhile especially when I slow down, the pipe rattles. I think its rattling against my exhaust coming up to turbo. I have flattened the pinch weld against the floor board, so I dont know what to do to get anymore room or to get the rattle to stop! Any help would be great Thanks!
fordtough97 is offline
Old 07-14-2008, 10:07 PM   #2 (permalink)
You need absolutly more room, so desintall the DP and use a porta-power with the duck part and make more room. thats it.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; gutted Kitty; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 07-14-2008, 11:01 PM   #3 (permalink)
Your downpipe was two pieces? I just put and MBRP in recently and it was one piece down pipe. The next piece had about an 8" section of 3" pipe that was welded to the part where it flares to 4". I'm not very happy with the fit of mine, I don't have any rubbing issues in the firewall area but it hit on my tranny crossmemeber. I can't rotate the downpipe any more cause then it will be hitting the tranny?
Dave
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
Old 07-15-2008, 12:26 PM   #4 (permalink)
Exclamation
Dave
Only one piece?, most if not all of the aftermarket DP are two pieces since 10 years ago (more o less). Did you buy it direct to the MBRP dealer or to some other people and it was modified?
Old 07-16-2008, 06:58 PM   #5 (permalink)
Turns out the pipe is not hitting the firewall, it is hitting the up pipe. So not sure how to make more room for that.
Old 07-16-2008, 08:01 PM   #6 (permalink)
now I dont know what to do to make room between the DP and de UP, sorry. Maybe if you hit with a hammer a little in the DP in the part that both has contact, just thinking in loud voice.
Old 07-16-2008, 09:54 PM   #7 (permalink)
turned out i just needed to rotate the pipe a little bit. Now it clears ok. Thanks for the help though!
Old 07-16-2008, 10:10 PM   #8 (permalink)
Glad to hear that. Any time.
Old 07-18-2008, 01:04 PM   #9 (permalink)
Black_Clouds's Avatar
Send a message via AIM to Black_Clouds
whats the easiest way to remove the stock downpipe?
Black_Clouds is offline
Old 07-18-2008, 02:20 PM   #10 (permalink)
I took the sawzall to mine and cut the pipe from top of truck and from below and it will come out just fine then.
