Old 10-06-2005, 05:40 PM   #1 (permalink)
3 quart semi truck oil filter!!!
Hey my powerstroke friends, I discovered something great. I don't know if it is already well known but I found a 3 quart oil filter that fits a powerstroke perfectly! that's right, 3 Quarts! Its either of these: Donaldson P554105 or Fleetguard 691.
I work the mechanics graveyard shift at a TA truck stop. things can get really slow some times. I am always around huge 1 gallon oil filters and I have been trying to find a way to use one of these monsters on my 97 stroker.
It was slow, so I removed my oil filter and took it in the back. I compared thread sizes and width with the monster oil filters. All caterpiller filters that we carry had matching threads! I found the longest filter that still fit the very tight clearance against the oil pan that powerstroke filters have, and it works like a charm! filters are around $17 and all truck stops carry these very common filters. hope this helps! I'd like to get some feedback or pros and cons! thanks guys.
2000 F-250 ex-cab, Long Bed, 4x4, 7.3L, 6-spd, 93K miles, k&n air filter, 285's, Black, 3 quart oil filter, more to come
Brianedwardss is offline
Old 10-06-2005, 05:42 PM   #2 (permalink)
My Photos: (6)
Re: 3 quart semi truck oil filter!!!
well hey.. cool.
Now we can carry 19 quarts instead of 17.. heh.. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Nice find!
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 10-06-2005, 05:57 PM   #3 (permalink)
My Photos: (11)
Send a message via ICQ to Fishhook
If the micron size of the filtration is smaller than ours then the slowing down of the oil through the filter will help it to capture more dirt and soot thus letting us run the oil longer. It might make economic sense to do it.
Greg
96 F250XLT,SC, PSD Hooked to a BTS Tranny, LWB 4x4 (4.10s), D60 Straight axle conversion, Isspro Triple A-pillar Guage Pack, Mag-HyTec Axle Cover and a few others.
My Truck
Pics Of Truck Stuff
Fishhook is offline
Old 10-06-2005, 07:36 PM   #4 (permalink)
My Photos: (22)
I actually find this post veryinteresting, I was kinda starting to get tired of the same things being repeated repetively. I just looked the LF691 filter up on fleetguards sight. It appears that there are even two BETTER filters to use. The LF691 is your standard Cellulose media. You can upgrade to LF3374 which is the same filter but with the BETTER Stratapore media. Finally thereis the LF9691 which is the combination Statapore full flow & stacked disc venturi style bypass. Of course this is assuming that there end up being NO issues using these oversized filters.
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
Old 10-06-2005, 07:41 PM   #6 (permalink)
My Photos: (22)
Some more info from fleetguard. The sixe specs for the standard filter are:
Part: LF3630
Manufacturer: FLEETGUARD
Part Type: Lube, Full-Flow Spin-On
Overall Height: 206.3 mm (8.122 in)
Largest OD: 108.36 mm (4.266 in)
Thread Size: 1 1/2-16 UN-2B
The size specs for the potential oversized filter are:
Part: LF691
Largest OD: 120.27 mm (4.735 in)
Overall Height: 287.27 mm (11.31 in)
Thread Size: 1 1/2-16 UNS-2B
With the Diameter being over 1/2 wider, I wonder if the rubber gasket has enough seating surface for long term use instead of just a quick fitment. I figure that is something to consider.
Hammer
I still have the:
Old 10-06-2005, 07:46 PM   #7 (permalink)
BlueMule's Avatar
My Photos: (12)
NO PROBLEMS at all, just takes a bit larger filter wrench. I bought a case of them on ebay, but when they're gone I plan on moving up to the stratopore version.
BlueMule is offline
Old 10-06-2005, 07:47 PM   #8 (permalink)
My Photos: (22)
Does it look like <font color="green">THIS</font> [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I've been using them for close to 3 years now! <font color="green">SEE!</font> [img]/ubbthreads/images/graemlins/cool.gif[/img]
That's good to know that they work long term...I do notice that you have signs of seapge on your filter though. Are you not going as tight as required to stop seapage or you can't get it to seal completely?
Hammer
I still have the:
Old 10-06-2005, 07:50 PM   #9 (permalink)
My Photos: (22)
I just looked up prices on Saveonfilters.com
LF691 (cellulose).........$11.38
LF3374 (Stratapore).......$21.18
LF9691 (venturi combo)....$30.42
Hammer
I still have the:
Old 10-06-2005, 07:55 PM   #10 (permalink)
My Photos: (11)
BlueMule,
Have you done any oil analysis and if so did it extend your oil change interval? What else have you learned?????
Grace us with your knowledge oh wise one [img]/ubbthreads/images/graemlins/grin.gif[/img]
Greg
My Truck
Pics Of Truck Stuff
Fishhook is offline
Old 10-06-2005, 08:00 PM   #11 (permalink)
Banned
Good find!!! Next oil change i will be swapping my filter out for a larger one these
luke
lukecline is offline
Old 10-06-2005, 08:57 PM   #12 (permalink)
BlueMule's Avatar
My Photos: (12)
You can get the Wix version (51722) of the LF691 HERE for $4.50
BlueMule is offline
Old 10-06-2005, 09:07 PM   #13 (permalink)
BlueMule's Avatar
My Photos: (12)
BlueMule,
Greg
I do send my oil out for analysis on a regular basis, BUT I also use synthetic oil and an Amsoil bypass filter. I had just a bit over 30,000 on the oil when I last changed it. The Amsoil filter and Mobil D1 gets the credit for that.
K-D tools makes a wrench thats fits the big filter.K-D #2321
BlueMule is offline
Old 10-06-2005, 09:25 PM   #14 (permalink)
My Photos: (5)
YOU GUYS RULE!
As long as the filter fits, and BLUEMULE has proven that, and it doesn't leak, also proven (seepage accepted) we've got several advantages of making this switch:
1. more oil capacity means cooler oil = good.
2. more filter media means longer life = good.
3. the choice of several filter medias = nice.
4. the fact that one maybe just as good media wise as the FL1995 but available on line for $4.50? = TOTALLY EXCELLENT.
(now is that $4.50 filter infact as good or even better than stock?)
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 10-06-2005, 09:46 PM   #15 (permalink)
BlueMule's Avatar
My Photos: (12)
Ooops......Sorry Guys [img]/ubbthreads/images/graemlins/frown.gif[/img] I was looking at the wrong filter # [img]/ubbthreads/images/graemlins/blush.gif[/img] I saw 51772 and thought it was 51722. Wix does make one to fit but its not listed on that site.
BlueMule is offline
