Old 02-28-2007, 11:39 PM   #1 (permalink)
35/12.5/16.5 AT tires, BFG stopped making them, anyone else make them?
I was pricing them today and one dealer said he had to call BFG to get me a price and when he called me back he said they stopped making them. Does anyone know of any other tire company that makes them? I have pretty nice wheels and I'm sure they aren't worth much if there aren't tires for them (so I prefer to not have to get new wheels yet). So if anyone knows I appreciate it.
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 135k mi.
psu927 is offline
Old 03-01-2007, 12:14 AM   #2 (permalink)
Re: 35/12.5/16.5 AT tires, BFG stopped making them, anyone else make them?
Have you tried calling BFG directly? They still list them on their web site. 1.877.788.8899 to reach BFG. I never trust dealers/distributers.
http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, 294,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, 436,000 miles
'95 Lance 11'3" Model 900
Diesel_Aggie is offline
Old 03-01-2007, 06:42 AM   #3 (permalink)
PSDfreak's Avatar
I sure hope not! [img]/ubbthreads/images/graemlins/crazy.gif[/img]
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 03-01-2007, 08:12 AM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
They are a great tire, but I am betting fewer and fewer 16.5" tires are being sold all the time.
It would not surprise me if they did. Part of business.
On a up side I pestered Dunlop for two years to make a specific size they discontinued for my motorcycle. The eventually began making it again. So anything is possible.
MarkEkberg is offline
Old 03-01-2007, 09:21 PM   #5 (permalink)
Pro Comp still had them last ime I checked, they work great for me!
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 03-02-2007, 05:28 PM   #6 (permalink)
i'll give BFG a call Monday, thanks guys
psu927 is offline
Old 03-02-2007, 05:50 PM   #7 (permalink)
My Photos: (22)
Man, don't scare me like that! I just called BFG. They have no plans to stop making that size. You need to get a different tire shop though! BFG, Parnelli Jones, and and Interco are about the only people I know that have this size. I doubt any of these are going to stop making it. While the 16.5" wheel is no popular in general, there are A LOT of them running around on modified lifted trucks. This post scared the crap out of me as I will be getting new 35" BFG's in the next few months!
Jerry
1997 F-350 XL Crewcab 4x4 SRW PSD a.k.a MEAN GREEN. DP-Tuner Chip, DIY Stage 1 injectors, D66 Turbo with 1.0 housing, K&N FIPKwith Amsoil element, 4" exhaust to 5" stacks, Banks intercooler, CCV modded to RDT, 4" Superlift with 35" BFG AT's.
1993 F-350 XLT Crewcab 4x4 SRW 7.3IDI non-turbo Project Truck
Jerry Miller is offline
Old 03-03-2007, 04:33 PM   #8 (permalink)
yeah I was scared to, I even thought about buying 2 sets if I could find them anywhere. Well I'm much more comforted now!. lol. I found a great dealer in the area, tires, mounted, and balanced all together for 810$. Good deal I think!
psu927 is offline
Old 03-05-2007, 06:09 PM   #9 (permalink)
PSDfreak's Avatar
I also checked into this...Was putting tires on my moms car for her over the weekend at Big O Tires...Asked the guy to look up 35x12.5x16.5 BFGs for me...says he had 3 sets of em and that they were expecting more from BFG soon...
PSDfreak is offline
