Old 09-27-2007, 11:15 PM   #1 (permalink)
DIESELDUTTON's Avatar
35" x 12.5 x 17" E Rated Tires
I have been looking for E rated 35's and cant seem to find any. Is anyone running them or do they not make them fo a 17" wheel? I tow my fifth wheel about three times a year and fully loaded it is about 8500lbs, have any of you guys switched from e's to d's that tow? If so did you notice a change with two less sidewall plys? I would love to e's but I just cant find them. Thanks Guys
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 09-27-2007, 11:28 PM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: 35" x 12.5 x 17" E Rated Tires
35" D tires hold more weight than a 31" E tires.
MarkEkberg is offline
Old 09-28-2007, 08:53 AM   #3 (permalink)
i think nitto and toyo make a good 35 with d or e but you are going to pay for it
1994 F-350 4x4 XLT 5 Speed. DP Tuner 4 position stock, 60Tow, 100Race, 140Smoke. AFE Intake, 3.5 Downpipe into 6inch miter cut stacks. Intercooler from 99, Exhaust Brake, Boost and pyro magtec rear cover, train horns, 181000 and counting
hitechredneck350 is offline
Old 09-28-2007, 08:53 AM   #4 (permalink)
pro comp as well
Old 09-28-2007, 09:57 AM   #5 (permalink)
i've towed plenty with 285/75R16 D rated tires up to 10,000 lb trailer weight and never had a problem. I think they handled the load just as well as when I had E rated tires.
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
Old 09-28-2007, 11:22 AM   #6 (permalink)
Thanks Guys, I'm gonna head up to English town\Raceway Park on Sunday, they are having there swap meet this weekend and everyone tells me they have everything and anything you would ever need for a truck or car. They tell me it takes three days to look at everything, but I'll have to do it one day [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] Thanks Guys
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 09-28-2007, 05:33 PM   #7 (permalink)
Send a message via AIM to Bobby77ss Send a message via Yahoo to Bobby77ss
Sounds like you'll be needing some caffeine and will definately be getting your exercise!!! Have fun!
1996 F-350 7.3 2WD Crew Cab Dually. 128,xxx miles, 2nd owner, PO was Lead Diesel Tech @ a ford dealer with flawless maintainence records.
K&N FIPK2 Cold Air Intake - Now with Napa Paper Filter, no more sandblasting my turbo wheel!
Diesel Turbo Lifesaver
Brite Box
4" MBRP with Missing kitty, no muff and 3" downpipe
Upcoming:
EGT, Boost, Trans Temp Gauges
99-03 intercooler *acquired*
with GTS or banks install kit
CCV Mod
EBPV into DIY Jake Brake
Custom Chip
D66
Built Trans
Bobby77ss is offline
