Hey guys, I am trying to figure out how to post a Bio, but in the mean time, I have a 97 ex cab, longbed with a Green filter, 3" downpipe, gutted cat and Edge EZ on her now. I am curious if a cat back four inch exhaust is really worth the money or if the stock straight through muffler and 3.5 pipe will do okay with these mods. Thanks for the ifo gang, it is good to not have to experiment and flush my money on stuff.
1997 ECLB F-250 4X4, TAT e4Od,4.10 Open Diffs,Superwinch Manual Hubs, 265/75/16 Force 4 AT's, DP Tuner F-5 5-Position (Stock,Hi-Idle, 40 Tow, 40 High Alt Tow, 80 Econo ),3"DP,4" Exhaust,Tymar Intake,Full gauges. Intercooled. ATS Turbo.
If you have $$$ burning a hole in your pocket go with the 4", but you should be fine without it.
John Deere tried to run a N/A 404 cid in-line 6-cyl. tractor engine thru a 1-3/4" exhaust pipe (side console 4020 diesel). Tractor was rated 95 HP @ 2100 rpm....and today they're still around 35+ yrs later. Your PSD has four times the exh. outlet area with the 3-1/2" system so You should Be O-K up to 350-400 HP.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
294,000 mi & NO Problems, LUK Clutch, and the Cat is buried in the back yard!
Don't get a 4inch dp get a 3.5 and you will be fine. The 4 inch give you problems trying to install it and you lose a little bit of power when you make it too big without enough upgrades. You can see what I had on my 7.3L it was pretty quick and the 3.5dp and 4inch exhuat was plenty for that truck.
__________________ 2005 F350 CC 4x4 Dually Lariat
Bean's Performance Turbo, DJ's SCT Xcal ,AFE Stage 2, Dual 4" Stright Pipe to 6 x 22 inch Tips, BD X monitor, 4" Cage OffRoad Lift, 35" PJ Dirt Grips, 2" Spacers On Rear Duallys, ect. ...
2001 F250 PSD CC 4x4 Lariat
TS 4 Pos Fuel 7, Water/Meth Injection, AIH, Cyclone Power Fan, Tymar Intake, 5R100 Converter, Transgo Shiftkit, 3.5 dp 4 inch stright Pipe to a 6 x 24 Inch Rolled tip, BD Xmonitor, BD Pressurloc, Detroit Locker in rear, 16 x 10 rims with 305/70/R16 BFG M/T.....Sold
You guys know of any place for dual 4"? Dale at tymar has one for like 400 i think, without muffler or cat...hehe, tymar 3-3.5-4" dp and the exhaust kit was like 550 bucks shipped...dont quote me because it was in dec when i got the price and I may be forgetting something.
SOLD**94.5 F-250 PSD Extended Cab, Cowboy Sleeper, Dual Open 3.5" exhaust, and Tymar Intake.
New** 99 F-350 CC 4x4 PSD, Cowboy Sleeper, 6" lift, 35" Cooper STTs, straight pipe.....more to follow!!!
When I put mine on my truck I noticed a big difference in performance. I think it would be well worth the money. Every bit helps.
96 F-250 R/C 4X4 7.3 POWERSTROKE E4OD, DANA 60 SWAP, 4:10 GEARS, SUPERLIFT 4" LIFT, 315 BFG ON 16x10 WELD SUPER SINGLE II WHEELS, SUPERCHIPS 1705 MICROTUNER, 3" DOWNPIPE WITH 4" MAGNAFLOW STAINLESS STEEL EXHAUST WITH A 5" MAGNAFLOW POLLISHED TIP. AFE STAGE 2 MAGNUM FORCE INTAKE SYSTEM, AUTOMETER TRIPLE GAUGE POD WITH AUTOMETER SPORT COMP EGT, BOOST AND TRANS TEMP GAUGES.
Heck Yeah, 4" is worth it...go straight pipe!
I have a bit more hp, and for sure an awesome roar and whistle with mine. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
'94 Ram 2500 Cummins 12V; 145K miles; 4" straight pipe exhaust with 6" Silverline tip; K&N; NO silencer ring; plate slide; new fog and clearance lights; KDP under control
I agree, even if it doesn't make a big difference in performance, the sound is well worth it. I love the added turbo whistle.
Just my .02
Don
1996 F350 PSD red and white crew cab with a 4 lift, 315 tires on KMC Intruder rims.Tymar 3" to 4" dp and 4+" dual exhaust no muffler or kitty, Authentic Tymar intake and HP x-over.Rockin S overhead gauge pod with Isspro hi-vis white face gauges in Pyro-Boost-Trans temp
Glow plugs at 110k Water pump and stat at 115k Luke clutch and flywheel at 135k and cps at 165k
Other toys
2006 ZX-14
1992 CR-500
2005( finish date ) Twin Turbo 4.9 ltr caddy 4-seater sand rail
Needs to find a new home, 2000ish kit built sand rail that started life with a VW motor and now has an all aluminum V8.
Sure its worth it, I got my complete 4" exhaust off ebay for $299 and it came with a 3" down pipe which I already had so I turned right around and sold the down pipe back on ebay and got $108 for it. Talk about cheap the whole system ended up costing me less than $200. It sure breaths nice and the sound can't be beat! Whatch ebay for good exhaust deals they can be had. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
__________________ 1996 F-350 4X4 SRW w/285/75R-16, 3.55 Loaded, AC,Ford AIC Diamond Eye 3" downpipe, Warpspeed 4" exhaust. Tony Wildman two position chip with Tow/Race. Autometer Phantom's Trans/Boost/Pyro New <font color="red"> JASPER E40D w/AMSOIL TORQUE DRIVE ATF </font> <font color="red"> AMSOIL Series 2000 75w-90 </font> gear oil in diffs, <font color="red"> AMSOIL 15W-40 Heavy duty </font> with <font color="red"> AMSOIL DUAL BYPASS FILTERS </font> , Stanadyne Performance, Napa coolant, Napa coolant filter(with SCA)4071, <font color="red"> Open air intake</font> ,<font color="00FF00"> keyless entry mod, tank mod, and pedal mod(big gain). </font>, Marinco block heater plug. Alpine 9811 with Kenwood six disk changer in back of seat and Poineer three way speakers .
MPG. around town mixed 13-16winter summer
Highway Best 20.1(unloaded)65-75mph
To do list- Babies/BTS
