Old 12-09-2006, 01:51 PM   #1 (permalink)
4 inch or 5 inch?
'97 Crew Cab Lond Box auto
we be needing some exhaust
turbo back-
4 inch straight pipe?
or
5 inch straight pipe?
2000 Crew Short F250 4x4 Lariat
White over Ebony
Limo Tint all the way around
F350 Blocks- 1 1/2" Shackle kit up Front
Eagle Alloys
265/75/16 Toyo Open Country M/T's
5" straight pipe
~sold~
1992 Ford F250- excab- 4x4- Canary Yellow- 12 valve Cummins Swap- NV4500 5spd-
"Ford Makes It-Cummins Shakes It"
Rip Rook's 4inch straight pipe exhaust
~custom~ fuel plate
Pump Timing Set to 17*
Isspro Pryo and Boost Gauges on the Pillar
rolling on 285's Toyo M55's
bananaboatford is offline
Old 12-09-2006, 02:06 PM   #2 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Re: 4 inch or 5 inch?
5inch is a waste of money but looks good.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 12-09-2006, 02:08 PM   #3 (permalink)
kfjensen's Avatar
Like Soaggy said, might change the tone in it a bit with 5" and it does look cool but otherwise not going to be any "performance" gains because both of the options are straight pipes
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 12-10-2006, 01:11 AM   #4 (permalink)
AlaskaRedneK's Avatar
And 5 sounds cool too [img]/ubbthreads/images/graemlins/smile.gif[/img]
-Stouff
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, ~111K miles/ 3-4" Down Pipe hooked to 5" Turnout Stacks, Isspro EV Guages, Tymar, 6 pos. Northern Diesel Performance TS Chip, 7.3 IC, gutted stock fan- w/ single electric fan, Stage 3 DIY Hybrids
In the garage: RacerX Tranny kit, headstuds, 910s, pushrods
Next: New TW tunes!
AlaskaRedneK is offline
Old 12-10-2006, 02:15 AM   #5 (permalink)
Nit
yep, dont need it but if you can get a nice system it does sound really good
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 12-10-2006, 06:39 AM   #6 (permalink)
I got 400 hp out of a stock muffler/3/5" tailpipe so why run a straight pipe? [img]/ubbthreads/images/graemlins/confused.gif[/img] I think you may actually lose some torque using a very large exhaust system.[img]/ubbthreads/images/graemlins/eek.gif[/img] Running full race exhaust systems on mildly modded trucks are not necessarily a good idea.
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
Old 12-10-2006, 11:39 AM   #7 (permalink)
Nit
DOesn't your sig say " 4" duals " now?, maybe stock with a cat is too restrictive, but bone stock is not that bad, you get a really nice 3-6 foot straight exhaust plume out the side, the 5" is far less, I think there is nothign wrong with a 4" system, I would never try to up sell a guy to a 5" as it really think it is unecassary, even if I do have one myself.
pictures
dirty30
Nit is offline
Old 12-10-2006, 12:11 PM   #8 (permalink)
Depends if you have to make up for your short commings? Cuz everybody wants that extra inch every so often,but they dont really need it, unless they drive a Duramax. Those trucks should have duel 6 inch stacks then.
1995 F-250 Regular Cab,4x4 OFF-ROAD, PSD. 3.55's. Canopy, Home Made Ladder Rack. Toyo Siped M-55. 1991 King Pin Dana 60. 35 Spline 4340 Stubs, Warn Premium Hubs. Duel BDS Front Steering Stabilizers, Flopro 3-4" Turbo Back SS Exhaust. 3" Sky RSK, SD V-code. Flip Shackle in rear. Polyurethane almost everywhere.
Piston_Bully is offline
Old 12-11-2006, 03:29 AM   #9 (permalink)
4" duals was easy, the 4" downpipe install is going to kill me. Ummmmm, maybe that's because I got a box with a set of BDs in it, Terminator installed and a KASB/tapercore/heads being mailed out Monday from a Utah zipcode. Santa is making an early drop off this year. Now got to save up for that shortblock I want.[img]/ubbthreads/images/graemlins/biggrin.gif[/img]
The old exhaust had gutted EBPV, downpipe, factory cat delete and the stock muffler with a Banks mandrel bent 3.5" tailpipe. The factory cat is THE restriction in the exhaust of a OBS truck. The factory muffler is a straight through design without much restriction. However, the restriction of the stock muffler probably is what keeps my 1.0 turbo (with 80k on it with stage IIs) alive when everyone else's took a dump. [img]/ubbthreads/images/graemlins/smile.gif[/img]
masami is offline
Old 12-11-2006, 12:35 PM   #10 (permalink)
I can get you a great deal on a 4" Turbo back system.
Horsepower Upgrades offers the industry first and only <font color="red">30 Day Price Guarantee!</font>
Ford, Dodge, GM, Hummer, Jeep, VW, Mercedes, Audi, BMW, Mini Cooper, Mazda, Porsche, Motor Homes, International, Agriculture Equipment diesel and gas performance products and more. 1-888-882-0003 / www.horsepowerupgrades.com
HP_Upgrades is offline
