Lift will ride rough tires will howl and shack your truck [img]/ubbthreads/images/graemlins/eek.gif[/img] and you will need a adjustable track bar..other than that [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] good luck!
cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
Cary is right about the lift riding worse then the stock ride. But your lift should have come with a track bar lowering bracket. That will work for you to be able to use the same track bar. An ajustable one is better as you can fine tune your axle placement but you'll be fine with the bracket and factory track bar.
96 F-250 xlt auto 4x4, 4.10's, ext cab, Red & White two-tone, Dana 60 front end with a Sky Man. Reverse Shackle Kit, Firestone airbag overloads, 35" tires. TYMAR intake, fillernecks, and hx hose, running Roan Switches, custom 4-position chip from Northern Diesel Performance, JS idm, Hypermax dp, 4" exhaust before tire, DIY exhaust brake, homemade AIC, 10k, shimmed reg, sonnex valve and tricumulater springs, Isspro EV gauges on pillar, Lund visor, mudflaps, and steps for the wife.
Oh yeah!! I almost forgot Swamped!!!!
Babies through Northern Diesel Performance.
