I assume you are asking because of where I live and not about the benefits of having ABS on slippery roads.
We have plans to relocate to a much more northerly climate in the not to distant future. I'm sure I'll get some grief for this especially this week, but we miss the snow.
__________________ 96 Roll-A-Long F-350 4x4 Crew: 110,000 miles, built E4OD, 1.0 housing, and 3"x4" down pipe.
I live in North central Colorado and good tires are your best friend over having ABS. Just about the best all around winter driving tire seems to be a BFG all terrain, they are awesome on ice
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
Maybe he is actually wanting a 4 wheel disk brake truck, not necessarily concerned about ABS? I'd love for my OBS to be 4 wheel disk, mainly because I HATE drum brake maintenance/repair.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RSD Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake * gutted ebpv * 4" exhaust & 5" tip * AlumaCraft diamond plate toolbox * custom antenna mount (108" whip) * Uniden cb * diamond plate bed rail caps * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25 * ccv mod * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * poly bushings (front) * Rancho RS9000 shocks * dual steering stabalizer * 60,279 on rebuilt engine (myself) as of 1/08
I'm still a full time lurker here since I don't have a PSD yet, but I have a question about ABS that I haven't seen come up yet.
One of the things I like about the 99 and up PSD is that they have real ABS on all four corners. Anybody ever added this system to an OBS?
You would have to have a computer and wheel speed sensors and stuff and a whole lot of fabbing, if ya need it bad just get a different truck, if you use threshold braking you can stop just about, not quite but close to as good as the same truck with it. Like said tires help more than anything.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
I understand that to add a modern 4 Wheel Antilock Brake System to an older truck would require, at a minimum, installation of exciter rings and sensors at each wheel, the ABS controller and all the electronics/computer to make it work. Most likely would require a conversion to rear disks as well.
I agree that having proper tires, braking technique, and driving skills are crucial in winter driving conditions. However, braking technique and skill don't equal the safety benefits of having ABS in an emergency braking situation on slippery roads. Again though I'm talking about a modern 4 wheel system and not the 2 wheel.
I was just wondering if anyone has tried it. I guess the answer is no.
No, haven't added it.
The mid nineties Bronos have 4 wheel abs. You could look for swap parts from them. The rear sensor is in the axle speed sensor. A single sensor like the speed sensors on our trucks. You would need the hyd control unit, the control module, front sensors, the pump motor, relay and accel sensor. Than wiring and plumbing. A major project.
__________________ TheRacer XBuilt E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Dieseland nitrous!
Family owned & sponsored by : FloridaNorth
why? thats the first thing i do to a car or truck when i get it si unplug the abs and take the light out of the dash!!!! i can stop the car better with out it.
97 crew cab short box f250 power stroke 4x4 automatic. 4.10s a stock other an 209500 miles first tank 18mpg, 4in exaust with no kitty or muffler now.
1983 F-350 Crew cab 4x4 4.10 5 speed 90 cummins 12v, turned up pump, centerforce clutch, stright piped,97 alcoa ford wheels, with custom built flatbed 265 85 16s
sold!!!! 96 crew cab short box f250 power stroke 4x4 automatic. 4.10s one wheel wonder 180000 miles, old chip no epv 3in down pipe, 5" STACK custom air cleaner (like tymar) custom bumper 285 85 16's
My preference would be to take the $ and add the rear disc brakes instead.
But, thats not what Azstang asked for. He's asking for any info on 4 wheel ABS. Too bad the 99 up F-series rears aren't a bolt in deal.
I had a 2000 F350 SRW PSD 4x4 with 4-wheel ABS discs, and its braking in snow, etc was amazing for an 8000# vehicle. I had BFG A/T 285s on it, then 255/85/16 Firestone A/T, and both were great in snow.
My current truck has no ABS at all, but it does have new brakes all around. It stops very well most all the time, but I believe the lack of ABS adds to stopping distance in seriously sloppy conditions. On the other hand, the Toyo A/T tires may just be the best tires I've ever driven. I think they stick better in rain and snow than the BFGs, are quieter, and cost less to boot.
As mentioned by others, tires are the most important thing, rivaled only by paying attention. Remember, 4x4 doesn't mean you can stop as well as you can go...
Josh
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 Toyo A/T (2nd set - got 55k from first set) on factory Alcoas, big front bumper w/4 really bright lights; F add-a-leaf, new alt x3, fuel pump, water pump, t-stat, fuel heater, vac pump x 3, PS pump x2, SD starter, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, 222k and counting...
Hadn't thought of wheel adapters. Rodney are you adapting OBS rims to a SD axle? Hmm, Is the Van axle a bolt in?
Sorry AZstang this is a hijacking [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
LMK Rodney.
Josh
How did you get rid of the ABS? I thought unplugging them would disable the speedometer or cruise control from what I understand. I'd love to disable mine. I've had many a close call from that rear wheel ABS that would not have been had they been regular old brakes.
Ron Hansen, 1997 F350CC, 4x4, PSD 110,000 miles all stock with stupid auto transmission unfortunately. 1993 Ford E350 Club Wagon 7.5L 11,000 miles, 1978 Kawasaki KZ650 motorcycle with 167,000 miles!
