Has anyone done this? I think I saw a post where CaryT put some lariat bucket seats in his and thought it looked great. Anyone know if the bench seat will fit?
The seats in the truck I have now are in great shape, but not nearly
as comfortable as the seats in my 2003 crew cab... I need seating for six so need to stay with the bench seat.
1996 crew cab 4x4 black psd BDP 250cc hyrbids BDP fuel system Stealthhinator dual ipr hpop
H2E TDP tuning 515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke Truck and misc pics
Where these a bolt in item or did you have to make brackets ect to make the 02 seats fit?
__________________ 1997 F250 XL 2wd 5spd 7.3 , SRW ,ext cab, Tymar air intake, 3"DP with 3" straight pipe, No cat or EBPV, "A" pillar gauge set with Auto-Meter Pro-Comp boost and Pyro, 265/75-16 with stock steel wheels, Custom conversion van bucket seats with custom console holding SFF PC with GPS and MP3
the front I redrilled holes to mount them. The rears I used part of the old seat brackets to mount the new ones so i could slide the seat forward and backwards. not a bad install. Just make sure you get them where you want them before you mount them;.
334hp 740tq
rdrcm #29
Did you hook up the power? My truck has the power lumbar leaky air bladder... think that would work for a power source?
Now I just need to find a set of grey seats!
i am a big guy (FAT) with a regular cab and need new seat
you people that have done this swap in a regular cab OBS trucks
HOW MUCH ROOM DO YOU HAVE BETWEEN YOU AND THE STEERING WHEEL???
1997 F 350 4X4, twildeman 6 pos., mod idm, bean` s stage 2` s and turbo, intercooler, 4" no muffler or cat and stack, fuel pressure mod and trans from brians ruck shop rear disk brakes, and a stecher stage 1 hpop
come on some of you expert, how anout your 2 cents worth
its back any of you experts want tp try, how much room between the wheel and driver????????????????????????????????????????
I have 40/20/40 first Generation lightning seats in my 96 CC front and back plenty of leg room up front and its a little cramped in back but it doesn't matter I don't sit back there!!!!Haha
1996 F-350, CC, Dually, 2wd, torreador red, tinted windows, rollpan w/hidden hitch, Cervini's fully functional ram air cowl hood, Diamond cut headlights/parking lights, billet grill, 93-95 lightning front bumper/ valance, lightning buckets and center seat in front, lightning buckets and subwoofer enclosure mounted in between, 2 10" diamond audio subs, Sony Amp, pioneer head unit, Eagle Alloy series 129/130 wheels, Bilstien shocks, triple pillar pod w/ stewart-warner boost, EGT, and Trans temp, Tymar intake, Tymar HPX, BD 45h.p. chip, Fumoto drain valve, fuel heater mod, Stancor GPR,Coolant Filter, Tymar 3x4" DP, 4" back turned out before rear wheels with Stainless 4"x5" slant tip
Mods to come: I have these just need to install: banks wheel, 203 degree thermostat
I have the front seats from a 2000 crew cab in my 96 regular cab. I didnt notice any difference in the amount of legroom but I did loose a bit of headroom because these seats are taller than the old broken down bench seat I had.
thanks for the info, am in the process looking now
