Old 05-13-2008, 01:02 PM   #1 (permalink)
Send a message via AIM to 97psd7.3 Send a message via Yahoo to 97psd7.3
400hp?
alright so i have a goal of 400 hp for my truck, i already have a new exhaust for it on there including a new downpipe. my question is, is it possible and what company would be able to help best? i plan on doing it all myself my biggest fear is doing the gauges like for the egt.
97 f250 7.3 powerstroke all stock cept for the 3in downpipe, 4in stright pipe to the 5in tip245,xxx miles and still going. avg 18-20mpg
97psd7.3 is offline
Old 05-13-2008, 01:30 PM   #2 (permalink)
BDDave's Avatar
400HP can be a tough go on that 97, not impossible, just tough!
Some tips would be obviously air improvements, especially the downpipe you mentioned, which you already have. Getting the fuel into the motor is the challenging part and despite what the ANY chip is rated for you will only ever see 70-80HP out of them because you are limited to the flow of your injectors. Performance Injectors are pricey but are vital to getting to 400HP on that rig.
I have seen guys run the snow performance water methanol kit on that truck and get some great gains, I would suggest looking in that direction as well as an intercooler.
Hope this helps!
03 Dodge Ram 2500 2WD Reg Cab
BD X-Tuner stacked with BD X-Power
BD Super-B Turbo and X-Intake
BD Dual X-Hale Stainless Exhaust
Toll Free 800-887-5030 ext. 105 Dave
dave@bd-power.com
www.dieselperformance.com
BDDave is offline
Old 05-13-2008, 01:51 PM   #3 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
Here you go Beans Diesel Performance . If you are a little scared about installing some gages get ready for some real work. The gages are the easy part.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is offline
Old 05-13-2008, 03:35 PM   #4 (permalink)
BDDave's Avatar
Not trying to sell ya here LOL, but if the install worries you, look at our digital X-Monitor, everything connects to a controller under the dash and you just run one wire up to the display, clean and easy!
I prefer analog myself but digital does have its advantages... memory feature
dave@bd-power.com
BDDave is offline
Old 05-13-2008, 05:22 PM   #5 (permalink)
Justin C.'s Avatar
If you want to do it on straight fuel alone, you'll need a set of Stage 2 injectors. With the right mods, they will go 400hp at the rear wheels. The other mods you would need are an air intake, tuner with custom tunes (to take advantage of the big injectors), and an after market turbo to burn all the extra fuel. Mods you might need are a 17* High Pressure Oil Pump and a Fuel System. Mods like Propane and water methanol will get you there quicker, but they're temporary power. My truck with the mods listed below is probably somewhere between 350-375 at the rear wheels. I still have the stock turbo, fuel system, and 15* pump (although my pump holds pressure fine).
Justin
Visit the Middle Tennessee Pullers Association at http://www.midtnpullers.com
1997 F-250 Power Stroke - 200k
Bean's Stage II's
TS 6 position chip - Bean's tunes
Tymar Intake
Southbend Con OFE
Grand Rock 5" Stacks
2005 F-350 Power Stroke (company truck)
All stock - 150k
Justin C. is offline
Old 05-13-2008, 09:59 PM   #6 (permalink)
Rtxcoon's Avatar
you can build a 400hp truck with some bolt ons....
gauges is the simplest part....if your already scared, time to do some research, all the other stuff is already documented and folks here will help
with all the rest...you can do it yourself, but you best be informed....
intake
exhaust
injectors
new chip
superduty hpop (or your flavor of some kind of oil system)
think about a fuel system
think about a new turbo
think about adding an intercooler, cuz there is no way you drive a 400hp truck without one
suprised no one has mentioned that you WILL NEED tranny upgrades...
some guys have gotten by with just a TC and valve body upgrades, but I dont think it will last being a daily driver without some internal tranny work as well, you didnt say if it was a auto or manual, either way, you'll need to address the transmission/clutch
there are other loose ends, but after you get started you can address them..
1997 F350 CC 4x4 Auto
435 rwhp on stock fuel and baby oil
Sky RSK, 35" procomp AT's, 3.55 gears Faubion Stage 3 E4OD(billet shafts, billet tripledisc TC) Wildman programs Bean D66 Dominator Turbo Bean Stage 3 injectors (238cc hybrids with big nizzles) 17* HPOP 5" Mitre stacks Tymar intake and downpipe Isspro guages, 6.0 CAC with Banks pipes/twin ram Wildman CCV mod IDM mod
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
www.tymarperformance.com
www.totaldieselperformance.com
www.beansdieselperformance.com
www.rspdiesel.com
www.ctperformanceinc.com
Rtxcoon is offline
Old 05-13-2008, 11:28 PM   #7 (permalink)
well my tranny was rebuilt with a new tc and shift kit from hallace performance, mike hallace a diesel tech for ford also was in the diesel power challenge 2008, everyone he has working for him are ford diesel techs. thing is charging me 550 for the 3 a pillar gauges is a little high, i have no problem doing the gauges myself just the hole drilling part for the egt probe has got be worried.
now question is tony wildman or dp tuner?
97psd7.3 is offline
Old 05-14-2008, 07:47 AM   #8 (permalink)
Justin C.'s Avatar
The tranny is still going to be a weak point for you. With 400 hp, you'll need a major upgrade. Sun Coast Converters Diesel Transmissions, Fort Walton Beach FL or Brians Truck Shop is who most guys go through. The EGT probe isn't a big deal at all, just make sure you put it pre-turbo.
Justin
Bean's Stage II's
Tymar Intake
Southbend Con OFE
All stock - 150k
Old 05-14-2008, 08:06 AM   #9 (permalink)
$550 installed for a painted pillar with 3 guages is a good deal.
Get a TW chip..no question. 2's as said 400hp easy. 17* pump may or may not supply ll the oil you need.Bigger turbo will be needed for longevity and increased air. D66 is a option.
Trans..long term you need a BTS.
Fuel system is a good idea.
Call Bean and talk over your goals ...he'll take good care of you.
Cary
95 f250 4x4 xlt Excab Lb. white, BTS Trans, 4.10ls, Dana 60, ORU RS kit DR 4"front 5" reas springs!, Bilsteins, Centerline 18x9", 37" Toyo MT's,H2e, Tapercore IC,3" Billet intakes, Tymar 4" exhaust,intake and HX mod,Beans 2's, Stealth and Fuel system and DI studs, JS's IDM mod, TW 4 pos chip,TSM Rear Disks, 198k miles. For sale from 100% stock to ??? PM for details
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 05-14-2008, 10:22 AM   #10 (permalink)
yeah i checked out their site and i guess i will be calling them.
97psd7.3 is offline
Old 05-16-2008, 07:43 AM   #11 (permalink)
Rooster's Avatar
Are you guys using the aftermarket fuel regulator return mod on these 94-97 rigs?
2002 F-350, 4x4 *Banks Monster Exhaust * SC-MicroTuner * Racor Pre-Pump Fuel Filter * Tymar * GatorHyde Spray-in Bed Liner * Custom -AN 6 Fuel Supply Upgrade with Regulator * Fuel Filter Housing Re-plumbed w/ Aeorquip's Teflon -AN 4 hoses & fittings * MagHytek Front & Rear Diff Covers * Royal Purple Full Synthetic Fluids in Tranny, Diffs, Transfer Case*
*Authorized GatorHyde Bedliner Dealer * ExtremeAire Magnum Air Compressor System w/ 14 Gallons of 150psi air
community.webshots.com/user/rooster444
My Axle Tear Down
My Axle Rebuild
Rooster is offline
Old 05-18-2008, 03:02 PM   #12 (permalink)
Blackpearl97's Avatar
i install my gauges all by myself it was easy. your egt temp probe you drill 21/64 hole then fine thread 1/8 tap and it screw right in.
Blackpearl97 is offline
