5" exhaust fitment 2wd dually - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-12-2009, 12:39 PM   #1 (permalink)
Greetings All,
I have been shopping around for a new exhaust for the '97 crew-cab dually in my signature. I've found several Diamond-Eye 4- and 5-inch aluminized, single pipe systems that fit within the budget (i.e. under $400).
Although I will not doing any of the serious, high-HP mods that would require the increased flow capacity of a 5-inch system, I am interested in the reportedly deeper, throatier sound they offer.
The question then is: will I have sufficient clearance over the rear axle to fit the 5-inch system? The truck is a 2wd (for the moment) with dual rear wheels and a gooseneck hitch.
Thanks in advance,
RD
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 02-12-2009, 03:20 PM   #2 (permalink)
Briansshop's Avatar
Here's a pic of my 5", made up from mandrel bends:
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,up on 38s, Baumann TCS controlled E4OD.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 02-12-2009, 08:56 PM   #3 (permalink)
Brian, I love your truck and your fab skills, but in this case I don't think there is much comparison between your truck and a 2wd.
I have a 5" TYMAR/Diamond Eye/ Motoblue system on my 96 CC which is at stock F350 height. The overaxle pipe and tailpipe don't have enough clearance and fit poorly and this truck is 4" higher than a 2wd. I wouldn't do it again on mine and darn sure not on a lower truck.
I will have to admit that it sounds mean when it comes on the turbo just right, but the rest of the time it is just choppy.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 02-12-2009, 09:19 PM   #4 (permalink)
Briansshop's Avatar
Yea, guess I have a little more room under mine. I considered running mine straight, no bends over the axle, but thought it would just look funny.
Old 02-12-2009, 11:37 PM   #5 (permalink)
That's just what I wanted to know. Thanks!
webshots
RD97 is offline
Old 02-14-2009, 01:01 AM   #6 (permalink)
That being said, I had a chance to be beside the wife's truck with the 5" in traffic today, kinda coaxed her into getting on it ("hell no you not passing me with a 6.9") and the sound was ............well it was almost a sexual experience at about that sweet RPM.
Old 02-28-2009, 05:26 PM   #7 (permalink)
RD,
Feel free to check out my pics. I've got a 97 SRW 2WD Crew Cab with a 5" system I got from Tymar. I have not had any issues with it rubbing. The clearance is tight, but doable. I finished it off with a 6 inch chrome tip. Installed it while laying on my back in the driveway. Hardest part was getting the old downpipe out. Other than that I love the system. Nice little turbo flutter when you pull off and a nice deep sound when you get in it.
1997 Ford F250 Crew Cab 4x2 with 7.3L. Tymar Intake, Bores bumper guides, J.C. Whitney chrome cab lights, Steel Horse Stainless Steel grab handles, Hornblasters 3 chime chrome train horns, 3" to 4" downpipe/5" exhaust into a Walker BTM/6" polished Stainless Steel tip. ISSPRO boost/pyro/tranny A-pillar gauges. Pioneer AM/FM/CD player, Polk speakers, kicker amp and 12 inch sub behind the back seat. DP tuner F-5 chip with stock,80hp tow,80hp econo,100hp, and smoke programs. Sonnax/Tricumulator valve and springs transmission shift enhancement kit.
My truck pics
SkidRowe38 is offline
