5" RSK pics - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-25-2009, 10:57 PM   #1 (permalink)
oldbluef250's Avatar
Talking 5" RSK pics
Alright I have searched and cannot find a single pic of someone with the 5" RSk in their OBS. I have the d60 and would use stock f350 springs. I dont care about the ride that much to have to mess with the bumper and what not. There arent made to ride like a caddy anyways. Also, how would 35's fit on this or possibly 37's? What would I need to have to make it steer strait and not wobble? I have heard of pitman arms and track bars, but dont really know what they are. Would I need longer driveshafts? Thanks
1996 F-250 POWERSTROKE, BABY SWAMPS TS 6 pos tuned by SWAMPS(stock, high idle, tow, economy, race, smoke), DIY intake, 4" Diamond Eye exhaust with 6" tip,6.0 intercooler, shimmed FPR, CCV mod
oldbluef250 is offline
Old 02-26-2009, 08:28 PM   #2 (permalink)
Rtxcoon's Avatar
pm BigK, if he still comes around...he is running the 5" RSK...
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
Rtxcoon is offline
Old 02-26-2009, 11:08 PM   #3 (permalink)
You would need a new drop pitman arm. You can find em about anywhere online, probably around 100 bucks. Probably need some new brake lines or extensions too. Your driveshaft should be long enough, but I've heard the driveshaft from an F-350 has a double cardon joint which can handle the steep angle alot better. So you may need to swap it out eventually. Other than that not too sure what you need. I'm puttin a 6" on mine and thats what I had to do so far.
Duden97-7.3 is offline
Old 02-27-2009, 11:28 AM   #4 (permalink)
Pitman arm is the cast steel piece attached to the output shaft of your steering box. The drag link attaches to the other end of the pitman arm.
Snowtow is offline
Old 02-28-2009, 08:05 PM   #5 (permalink)
i have a front reciever...would it still work
97 F350, Custom intake, 5in exhaust, HPOX,17* HPOP, Rosewood stage 1 injectors, Powerhungry chip, 18k dfuser mod, shimmed FPR, 6 in lift on 37in interco M16 radials, firestone ride right air bags, built trans, bully dog shift kit, 12,000 HID headlights, 12,000lb winch in the front and a 9,500lb in the back, custom strobe package in headlights and taillights, LED bed lights, DVD, navigation, and much much more to come.
pullinstroker is offline
