Re: 6.0 L intercooler
LOOKIN FOR SELECTABLE LOCKERS(Electric ones) someone tell me when they are coming out?
sorry to go off topic on your original question, but you sure ask one of mine right there...what's taking these guys so long.....the electrac is out for the D60, but the ole Sterling is waiting for something in between. Maybe the ar afraid of all of the torque?
On your intercooler install. There are two easy ways to do it as you said. For the Banks install kit, go back a few days and look at rtxcoon's posts on it. On GTS, go to GTS Motorsports .com There are several good install articles on here as well. I'm not good at the links and such, if I see something I think I'll need later I print it out!
Diesel Mechanic 28 yrs
