6.0 in a OBS....NOT - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 07-10-2005, 06:50 PM   #1 (permalink)
Feedback Score: 3 reviews
6.0 in a OBS....NOT
[img]/ubbthreads/images/graemlins/laugh.gif[/img] well after a lot of compairing my 04 Ex with the 95 I have come to my senses [img]/ubbthreads/images/graemlins/smirk.gif[/img]. Getting the engine and trans to fit would be doable, granted it would take some fabing but nothing to bad the problem is useing my transfer case. That was a wake up [img]/ubbthreads/images/graemlins/laugh.gif[/img] to reality too many things envolved. If someone had a 2 wheel drive truck and blew the engine I think its something to take a hard look at. So now its time to get back on track and deside what mods are next in my search for 400hp [img]/ubbthreads/images/graemlins/wink.gif[/img]
Cary
Cary
caryt is offline
Old 07-10-2005, 09:43 PM   #2 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
Re: 6.0 in a OBS....NOT
Are the SD T-cases that much different than the OBS?
-Michael
Michael Paul
1997 F350: Regular cab, 7.3L PSD, 5-Speed, 4x4, 3.55 LSD, gauges, chip, Swamps injectors, Modded H2E turbo, 4" exhaust - 6" tip, Dual disc clutch, fuel system, stock oil, stock headbolts - 401 Hp/807 lb-ft, 14.3 @ 93.5mph
My Webshots
Dieselfever78 is offline
Old 07-10-2005, 11:03 PM   #3 (permalink)
brahamfireman's Avatar
Divoreced T-case.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 07-11-2005, 11:18 PM   #4 (permalink)
Big K's Avatar
Send a message via ICQ to Big K
Divoreced T-case.
Diesel Rod
Yeap, I agree! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Kevin "BigK" Neal
North Texas Power Stroke Association
972-768-7252
97 F250 "Sherman Tank"
Big K is offline
Old 07-12-2005, 01:09 AM   #5 (permalink)
the ones on the 6.0 are allot different, they have a shaft that goes in to the trans, the out put shaft of the tranny in on the t case.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 07-16-2005, 12:48 PM   #6 (permalink)
Dont you think that if one found a two wheel 6.0 you could get a yoke put on the T-Case from his OBS and make a divoreced T-Case set-up?
Still sounds like alot of work to me though. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Diesel Rod
Old 08-07-2005, 09:40 PM   #7 (permalink)
We got a new guy at work that says he has an Uncle in FL that did a 6.0L converstion to an OBS truck. I told him to get ALOT of pictures for me and I'll believe him [img]/ubbthreads/images/graemlins/vomit.gif[/img]
-Michael
Michael Paul
My Webshots
Old 08-07-2005, 09:46 PM   #8 (permalink)
My Photos: (6)
Why would you even consider doing that??? The 6.0 is clearly inferior to the cummins. If you wanted a modern repowered obs truck,, put a common rail cummins in it.
1997 F-250 xl, extended cab, 4X4, 5spd, , autometer boost and pyro gauges, 285/75 liberators, Dana 60 kingpin (freebee), bb fpr, and a big sratch in the paint, bdp stage 1s, dptuner 6 way chip, south bend clutch con o-fe,,,,,,,,,thats all for now.
chainfeed is offline
Old 08-07-2005, 10:05 PM   #9 (permalink)
Or if you still wanted the 6oh, why wouldn't you just bring the 6oh t-case with it? It's still a driver's side drop right? That would be insanely simple would it not? Maybe make up some driveshafts and engine tranny mounts. Then all the little bs, like intercooler/radiator/computer harness routing. Seems pretty easy as far as engine swaps go. If you didn't have one with a T-case though that would be a raw deal. Unless you just got a t-case for it in a junkyard. I think this may be getting inadvertantly over-complicated.
And if you had to loose the t-case, go with a divorced 205 from a 70's f-250. I don't think you're gonna break it lol. There are a million answers to this. But by far the full swap, engine/tranny/t-case would be a cinch I would think. I know I've done some rough ones, and this seems pretty straight forward.
Maybe I'm just missing the bad part though, I dunno.
Charlie
CharlieII is offline
