IS there a difference between the 6.0 and 7.3 IC? GTS is back with some more kits, but I have a 05 6.0 IC and dont want to spend the dough if the inlets are different.
TIA,
Travis
1995 F250 ext cab 4x4. K&N FIPK, Banks TOP, Magnaflow exhaust, Bean's stage 1's, Bean's 6 pos chip. Running on B100. Ready for WVO
4" Superlift on top of a kingpin D60 39.5 Swamper Iroks www.smithdiesel.com
Put it on, the core is bigger.It is good for a confirmed 100 degrees drop in egts.
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
what about the CFM flows on both of them? anyone know?
Reason I am asking is I keep hearing that the stock 7.3/6.0 intercoolers are too small for our engines on anything larger than stage1's (for optimum performance/efficiency).
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
I think there big enought. I had no temp problems...empty with 2's, TW chip amd my little ATS IC running thu Hy 50 in the mountains as hard as I could. Its really strange nailing it in the hills and watching everyone behind you pull over cause of the smoke [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
I was talking about this just last night with some friends as well.
What about the pressure drop with the 6.0 cooler as opposed to the 7.3 ?
The same idea. Both are related. I seem to recall that the 6.0 has more flow potential but the end tanks are more restrictive versus the 7.3, so it is sorta a push.
Now I am not saying that we wont see an improvement, but with the larger injectors, I am thinking that any stock intercooler is gunna be too small to support the potential air flow that lets say 170cc of fuel would require. All this means is that the engine would not have the top end that say a HyperMax Tapercore would have, but is it really a noticable difference say between 2000 and 3000 RPM?
Once again, anyone have any hard facts on the airflow capacities of the intercoolers, or emprical data on pressure drop on any of the intercoolers?
Aside from needing the NAPA 1740 3x3 boot for the driver's side, the tubing and brackets for either intercooler should be the same, the 6.0 version just hangs down a little lower and has a slight offset on the inlet height.
The 6.0CAC has larger tanks, how can they be more restrictive??? The 6.0 core also has more flow. The only thing that could be considered restrictive is the drivers side connection is 3" versus 3.25" on the 7.3CAC. But considering the CAC tubes are also 3", I really don't see this as a restriction.
