6 speed in OBS? - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 09-12-2007, 04:05 PM Thread Starter
6 speed in OBS?
Has anyone ever done this or do you know if a 6 speed from a SD will fit in our trucks?
97 F-350 Crew Cab Long Bed 4x4
93 Mustang Hatchback Road Race Car
88 CRX Si 36mpg Daily Driver
71 Bronco 302, 3 On The Tree
gofastnews.com
NoSpark is offline
post #2 of 17 (permalink) Old 09-12-2007, 04:39 PM
Re: 6 speed in OBS?
A couple of people have done it. IIRC the big hurdle is that you need the super duty transfercase as well.
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #3 of 17 (permalink) Old 09-12-2007, 04:42 PM Thread Starter
Re: 6 speed in OBS?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: garbage_mechanic</div><div class="ubbcode-body">A couple of people have done it. IIRC the big hurdle is that you need the super duty transfercase as well. </div></div>
It figures there'd be some sort of road block to make it cost prohibitive.
gofastnews.com
NoSpark is offline
post #4 of 17 (permalink) Old 09-12-2007, 04:56 PM
Re: 6 speed in OBS?
I've never actually looked into the difference in the trans to TC connection to see if anything can be done about it....need to contact advance adaptors......
post #5 of 17 (permalink) Old 09-12-2007, 05:51 PM
My Photos: (13)
Re: 6 speed in OBS?
It is a different spline count.
Tim
'97 F350 crew cab 4x4 lwb xlt 5 speed 225hp
'95 F250 reg cab 2wd xl auto 215hp
75f100 is offline
post #6 of 17 (permalink) Old 09-12-2007, 07:37 PM Thread Starter
Re: 6 speed in OBS?
It's not worth all of that. I'll just do a 5 speed.
Thanks guys
gofastnews.com
NoSpark is offline
post #7 of 17 (permalink) Old 09-13-2007, 12:15 AM
Re: 6 speed in OBS?
It's not that bad if you get a 6-speed and TC together used.
Oh and you gotta relocate the trans crossmember, but seriously, it's not that big of a deal!
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD
Mods: Swamps tunes, Swamps 275/226's, a Gen3, a BTS, Comps, Crowers and H11's up top, S465/TN II mount kit, Custom Comp. fuel system, and an IC.
smokyred is offline
post #8 of 17 (permalink) Old 09-13-2007, 08:12 AM Thread Starter
Re: 6 speed in OBS?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: smokyred</div><div class="ubbcode-body">It's not that bad if you get a 6-speed and TC together used.
Dave </div></div>
The work isn't the issue it's the $$$. I have to figure in the cost of a clutch/flywheel as my truck is automatic now. In my neck of the woods in the rare event that you come across used parts that have the word Diesel any where near them you pay like 10-20% less than new cost.
gofastnews.com
NoSpark is offline
post #9 of 17 (permalink) Old 09-13-2007, 09:18 AM
Re: 6 speed in OBS?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: NoSpark</div><div class="ubbcode-body"> I have to figure in the cost of a clutch/flywheel as my truck is automatic now. </div></div>
Then you better figure that in for the 5-speed also. Unless the donor truck already has the SMFW, you will need a complete SMFW LUK replacement assy. Dont waste your time with the stock dual mass flywheel, it will break things. Best case your tailshaft or bell housing, worst case your crankshaft. IOW, you may be able to get the 6-speed with FW and clutch along with the transfer case.
96 F-350 4x4 CC LB, International block and heads from Mcandless IH in Denver, <span style="color: red">Baby Swamps </span>, Luk Cerametallic Clutch, 5" straight exhaust,5 speed ZF, 4.10's, Evolution programmer, Banks brake, non-EBPV IH turbopedestal, AFE Magnum force, CA reg. kit, 12,000 lb. Milemarker on reciever mount, 215amp ambulance alt., 33" muds on factory aluminum, Class 5 bumper hitch, hidden gooseneck, pillar gauges, fosgate amp, 12" sub.
Colorado National Gaurd.
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independece. When Firearms go, all go's. We need them every hour!"
President GEORGE WASHINGTON
bigbore is offline
post #10 of 17 (permalink) Old 09-13-2007, 11:10 AM Thread Starter
Re: 6 speed in OBS?
I've figured in the luk clutch in the swap. It's the T-case that's the extra expense. Mine t-case works fine, as I mentioned parts like that around here are close to new prices.
I realize I put the clutch/flywheel in the earlier post.
gofastnews.com
NoSpark is offline
post #11 of 17 (permalink) Old 09-13-2007, 11:17 AM
Re: 6 speed in OBS?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: NoSpark</div><div class="ubbcode-body">I've figured in the luk clutch in the swap. It's the T-case that's the extra expense. Mine t-case works fine, as I mentioned parts like that around here are close to new prices.
I realize I put the clutch/flywheel in the earlier post. </div></div>
In that case, maybe be a little patient and save up the pennies for the t-case also as long as your AT is holding up. As long as you have to do a conversion, might as well do the best you can. In additon get the upgraded clutch so you can handle future HP upgrades. I would love to have that extra gear, lower 1st, higher OD.
I've often dreamed of finding a wrecked manual 350 SD and taking the whole drivetrain axles and all for my truck, then using the left overs to build an older F truck with a Cummins.
bigbore is offline
post #12 of 17 (permalink) Old 09-14-2007, 06:56 PM
galaxiedan's Avatar
Re: 6 speed in OBS?
Don't forget to figure in the money you can make from selling the stock TC and auto trans. You would be suprised at the amount of people that could use them.
, SRW ,ext cab, Tymar air intake, 3"DP with 3" straight pipe, No cat or EBPV, "A" pillar gauge set with Auto-Meter Pro-Comp boost and Pyro, 265/75-16 with stock steel wheels, Custom conversion van bucket seats with custom console holding SFF PC with GPS and MP3
, standard cab (spare truck)
Jardine pipe, K&N cone on carb, Dynajet jet kit, ACE nerfs, plus more!
galaxiedan is offline
post #13 of 17 (permalink) Old 10-18-2007, 06:48 PM
stout99's Avatar
My Photos: (5)
Re: 6 speed in OBS?
Where's the emergency brake on that truck? Isn't it on the tranny in the manual shift (ZF5) trucks?
early99 F-250SD Lariat, 4x4, 7.3 PSD, Banks Stinger(4"from turbo back, bighead wastegate actuator, guages, chip), Dieselsite Boots, LUK clutch, Moog balljoints, Leveling lift, Line-X bedliner, 285/75/16 BFG MT(E), Bilsteins, Dieselsite hpx hose, various beauty marks, In need of real tunes!!
stout99 is offline
post #14 of 17 (permalink) Old 10-19-2007, 03:21 PM
My Photos: (6)
Re: 6 speed in OBS?
eh? as far as I know, all our trucks have the emergency brake on the same location, in the rear drums.
2006 F350 CC 4x4 Lariat, Amarillo edition
SOLD - '95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60,
with SD V code springs, 175K miles, ATS 1.15 BB turbo,
Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes,
6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes,
, straight exhaust, 200PSI train horns and 215A alternator..
radarman is offline
post #15 of 17 (permalink) Old 10-19-2007, 03:58 PM
Jeremy's Avatar
My Photos: (13)
Re: 6 speed in OBS?
He's thinking of the 88-97 F-Superduties. The parking brake was on the back of the Transmission. Very $$$$ to fix.
11 F350 CC King Ranch Auto 4x4 stock for now
07 F350 CC King Ranch Auto 4x4 PHP FICM, PHP Gryphon Custom Tuner
06 F250 SC XLT Auto 4x4 LWB 3.55 gears, PHP FICM, CTS Juice(with PHP custom tunes), studs, EGR Delete.
05 Excursion Eddie Bauer Auto 4x4 PHP FICM, CTS Juice(with PHP custom tunes), Studs, EGR Delete, ctperformanceinc's XF suspension mods
00 F350 CC Lariat PSD 4x4 PHP Gryphon Custom Tuner 6 speed, US Gear OD(dead looking for parts),
95 F-Superduty PSD Auto Mechanics Truck
94 F-Superduty PSD 5 Speed 12' flatbed
93 F-Superduty 7.3 IDI N/A 5 speed 12' Dump box 60,000 org. miles
Jeremy is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
