Hey Guys, I have a 97 PSD 7.3 and I was thinking of getting a muffler delete pipe for it. What are the pro's and con's of doing this? I have seen alot of post about doing it to the 6.0 and not so much about the 7.3.
__________________ 1997 Ford F250 w/7.3 Powerstroke 5spd
1985 Ford Ranger 2.8 v6 Bone Stock and it couldn't pull a stick around
I'm in for that.. Exit right before rear tire? What four or five inch pipe? I have a 2" body lift on the wish list just to clear the larger down pipe it would be nice to skip the cat and muffler..
I'm NOT a mechanic but I will work until all my knuckles are bleeding to keep my 1997 7.3 4X4 on the road..
I would love to bring it out right at the tire!! never thought about that. I am sticking with the stock 3.5 inch exhaust until i can afford to replace EVERYTHING with 4". I just can't seem to find the 3.5" pipe to do it with. i checked muffler shops and hardware stores but nothing! Any sugestions?
I thought about shortening everything because I could re-purpose the old exit. Just less the muffler. Mine has the Cat about 30" of pipe the Muffler then over the rear axle and 90 degree out. If I remove the muffler and just pull everything back to the CAT hook up it should work with minimal fab. I also tapped on my CAT and she sounds 100% solid like no hallow effect. If the rain stays away today I may take a closer look snap some pics and report back. Sure wish I could weld. I would make a CAT delete pipe.. Hmm, muffler shop in town maybe a quick drive into town this afternoon.. I'd pay 30.00 for the pipe..
Depending on how you use your rig (daily driver vs pulling), I would point out that the factory muffler is a straight-through design, so very little back-pressure. For performance help, get rid of the factory down-pipe and cat. TYMAR Performace out of Spokane, WA can set you up with the down and delete pipes quite resonably. Now if its noise you're after.....ditch the muffler!
'94 1/2 F250 4x4, SuperCab XLT, 5 spd, SMF w/ Valaeo clutch, 4.10 (syn. lube), Cenex Maxtron 5W40 Syn, manual hubs, B&W Gooseneck hitch, Toyo M-55 tires in 235/85R16, authentic TYMAR intake, 4" AFE exhaust, FRP mod., SD starter, Isspro boost/pyro,digital thermometer, homebuilt exhaust brake, 175K "Its only a pickup. Trucks have a button on the shifter!"
As soon as the funds are available Tymar will be hearing from me.. With everything I read HE is the only guy for me and Big RED.. For now I try do to what I can with what I have..CAT must go and the muffler isn't doing anything anyway so sawzall and good by.. That down pipe I have to pay for though.. I would like to do a CAT delete pipe just in case Emission regs hit me here in TX..
My pops pulled his exhaust off and put a intake system on his Dodge and bam the state popped him on everything.. Would have cost him 3K but thankfully there is a group of guys that can be paid to look the OTHER way..
The talk about re-routing the exhaust to in front of the rear wheel got me to remembering. Dad had a '85 250 with the 6.9L, we bought it a year old, 19000 miles. Some kid had it and traded, dual exhaust out in front of the rear wheels with glass-pack mufflers! That damn thing would bark! But, the exhaust helped as that pickup always had more oomph and fuel economy than the others like it in the neighborhood. Old green burned up at the 350K mark, dad figured that was the most economical pickup he had ever owned- purchase price, upkeep, fuel, and insurance settlement!
Well, I went out and removed the tail pipe section and the muffler. The muffler is just what Tbeck said a through pipe with little to zero back pressure. Damn thing weighs a ton to. Now I just need to get this rain to stop so I can remove the last two bolts and remove the CAT. I talked to a local guy and he said Orielly's carries misc bits and pieces for exhaust systems. For this little project I don't need much just a mounting bracket about 6" of pipe and I should be able to reuse a mounting bracket and the 90 degree sweep. If I am lucky they will have the two bolt flange and the rest is gravy.. Once the rain stops I will snap some pics of the old parts.
G$
semi tractor shop!!
