7.L PSD Swap from 6.9L Information? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-23-2008, 09:42 PM   #1 (permalink)
Currently have a 93' model F350 4wd with a 6.9 in it. Originally had a 7.3L IDI Turbo. Has the ZF 5spd. Is the Powerstroke (94-97) a direct bolt into the frame/ trans? Any information would be greatly appreciated. Thank you.
Last edited by cbmind; 02-23-2008 at 09:42 PM. Reason: Missed something in the title
cbmind is offline
Old 02-23-2008, 11:59 PM   #2 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
I wouldn't fool with it !! I know a guy with a '93 truck that has a '97 engine and its a bit PITA!!!
For the time and money that you would have in it you could just find truck like yours (in better condition probably) and just buy it out right
-Michael
Michael Paul
1997 F350: Regular cab, 7.3L PSD, 5-Speed, 4x4, 3.55 LSD, gauges, chip, Swamps injectors, Modded H2E turbo, 4" exhaust - 6" tip, Dual disc clutch, fuel system, stock oil, stock headbolts - 401 Hp/807 lb-ft, 14.3 @ 93.5mph
My Webshots
Dieselfever78 is offline
Old 02-24-2008, 05:02 AM   #3 (permalink)
its alot of work.you will need a complete donor truck.you will need to swap every bit of wiring under the hood and dash.complete dash removal is required.im not sure but i believe the input shaft on the zf is different between the idi and psd trannys.but im sure somebody will correct me if im wrong.the psd will bolt right into your truck with no mods to the frame or anything.but you will also need the 94.5-97 psd radiator support as the psd radiator is larger than the idi radiator.you also need all the accesories and brackets for the psd.
only way id consider doing this is if you got ahold of a donor truck dirt cheap and your 93 was in almost perfect condition
94f450sd is offline
Old 02-25-2008, 02:46 AM   #4 (permalink)
Keep the 6.9 and just built the piss out of it for the same money. Just my two cents.
1993 Bronco, 351, 5 speed conversion, 6 inch lift 35's. In process of one ton swap.
1996 F-150, I6, 2wd, regular cab, shortbed, reliable as hell.
2003 Harley Davidson sportster, 1200, 100th year edition
2007 Yamaha YFZ450, to go where the Bronco cant
2002 Ford F-350 7.3, CC, LB, auto everything, 315/75/16 with level kit only, Torador Red, BIG RED
B-rad is offline
