93 IDI to 94 powerstroke engine swap.. - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 01-14-2009, 10:59 AM   #1 (permalink)
polcat's Avatar
Just curious on the guys that have done this?? I have a chance to get a wreck 94 truck with a Powerstroke in it that has alot less miles than mine and was curious about doing a engine swap. I know the DI is all electrical so I am hoping with having a donor truck i can just move all the wiring harnesses and fuel pumps over to the other truck. Radiator, after cooler.etc. Anything I need to look for? Also are the transmissions the same as far as the standard 5speed. Curious if I need to swap transmission too? Any input would be greatly helped. Supposly this truck has been sitting a few years. So I am going to try and start it before I buy it just to see. Thanks Fo any of the help.
polcat is offline
Old 01-21-2009, 01:10 PM   #2 (permalink)
Polcat, it is a pretty straightforward swap, but it is a lot of work. The worst part of it is swapping out all the wiring harness. I think you will have to change all of it, including under the dash, ecept for the harness going to the rear of the truck. Your tranny will work fine, use the PS flywheel. No need to worry about fuel pumps, both truck use an engine mounted lift pump.
Good luck,
Tim
"Better to be hated for who you are, than loved for who you're not." - Van Zant
My Truck 1972 F-350 4x4 Extended cab 14-36 Swampers, 97 Powerstroke, 4 position chip with custom tunes, 3" downpipe, 5" exhaust, 99 intercooler, DIY E-fuel, Dana 60 front, 70 rear, lockers in both ends.
<font color="blue">72 POWER STROKE</font> <font color="red"> INTERIOR PICTURE </font> <font color="blue"> ENGINE PICTURE </font>
Wifes' Grocery Getter 99 F-250 SD 4x4 XLT Lariat 4 door. 7.3, Auto, 4 pos Bullydog chip, 3 1/2" downpipe, 5" straightpipe, Genuine Tymar, Stage 1 Monsterbox, 33-12.50-16.5's
72Pstroke is offline
