cams76 -- Not to complicate your life but everything I have seen says Ford introduced the Power Stroke in early February 1994 with the ZF 5-speed manual transmission. The E4OD automatic transmission was not available until the 1995 model year. You can always double-check the engine with the VIN. If the truck has a Power Stroke, the 8th position will be an "F."
Cheers from Orlando, FL! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dave
__________________ 1996 F-350 XLT CC SRW 4x4 with plenty o' Redneck Bling: APCM●BTS-E4OD●4L10●MADDOG injectors●Hypermax H2E, intercooler, & exhaust●TYMAR intake & HPX●TSM disc brakes●Hydro-Boost●International water pump●215 amp generator●CCV re-route●285/75R16 Wild Country XTX tires●Centramatics●Denon DCR-830RD & DCH-520 203,000 happy miles DZLJIM 3:16 ~~NTxPSA - Hold my beer and watch this.~~
the truck is stock and it says turbo diesel under the f 350 emblem not powerstroke. could it still be a powerstroke? it is a 5 speed
i looked at the engine and it had a garret turbo and the valve covers looked diff than my 1993 7.3 idi they were black and almost looked like plastic
93 f350 5 speed cc long bed 4x4 162,000 mi 4 inch lift 35" tires.
76 early bronco in resto.
southern oregon on the coast brookings
the truck is stock and it says turbo diesel under the f 350 emblem not powerstroke. could it still be a powerstroke? it is a 5 speed <font color="blue">95 powerstrokes still had the turbo diesel badge and were only available with a 5 speed. </font>
i looked at the engine and it had a garret turbo and the valve covers looked diff than my 1993 7.3 idi they were black and almost looked like plastic <font color="blue">PSD's have a garrett turbo and blac valve covers. Powerstrokes have an internal fuel rail in the heads, unless it has external fuel lines like your IDI it probably is a PSD </font>
Powerstrokes have a cartridge fuel filter in the canister that is in the valley, IDI has a spin on filter. </font>
cams76 -- '94 Power Strokes still had the "Turbo Diesel" badge under the F250/350 badge. As Rodney said, '95 saw the introduction of the "Power Stroke Diesel" badge.
If the turbocharger said Garrett, it is a Power Stroke. The turbocharged 7.3L IDIs used an ATS turbocharger. In fact, the basic engine is the same for both the turbocharged and naturally aspirated 7.3L IDIs so if the engine looked different than your '93, it is a Power Stroke. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Check out the Components section (scroll all the way down) from the 1996 F-Series Workshop Manual for some diagrams of the Power Stroke.
Dave
94Smoker -- Technically, yes; Power Strokes were in production in late '94. [img]/ubbthreads/images/graemlins/wink.gif[/img] Buuuut, Job 1 for the Power Stroke was in early '94. TSB 95-05-19 is why I say that.
Dave
I wasn't trying to say that I didn't believe you. My truck is a '94, and I made sure about asking the seller if it was an acutal Powerstroke, and he said yes. I was just making sure what he told me was correct. [img]/ubbthreads/images/graemlins/cool.gif[/img]
1994 F350 PSD Extended Cab Dually
5-Speed
144,000 Miles
Full Pillar Autometer Z-Series Gauges
Stancor GPR
K&N Intake
Gutted EBPV
3-Inch Downpipe
4-Inch Exhaust
Killed The Kitty & Muffler Deleted
6-Inch Turndown Tip Pointed Straight back
More To Come....
you can look under the hood, if you see a round airfilter it's NOT a powerstroke, and there should be the fuelfilter cover right in the center of the motor that says Direct Injection or DI(powerstroke)
94 powerstroke 5 spd, 4x4 xcab longbed,5 spd, 189.000 miles 4.10 gears, tymar style open intake, 3" DPPI downpipe, South Bend clutch, Edge EZ,pyro gauge, 1" front lift, Firestone airbags rear, 285 Toyo a/t tires, BB in fuel regulator http://good-times.webshots.com/album/55769610
Go to my albums.
My 95 has Powerstroke emblems and an E4OD..............
'95 XL SuperCab, LWB, 4X4, 204,000 miles, E4OD, 4.10 LS(when it wants to be!), body lift, 305-70-16 Cooper STT's on 10" Eagle Alloy wheels, "Brand X"-inspired home-made open-element air filter, 3" downpipe & 4" straight pipe with 5" stainless tip exiting in front of the rear wheel, 6 pos. TS Performance chip (going to visit T. Wildman soon, I hope), FPR mod, A/C mod, MileMarker manuals, onboard air (York running off the alternator...1 five gallon tank) with dual Grover air horns
2000 Jeep Wrangler Sahara Edition, white w/tan top & interier, 119,000 miles, 4.0L, auto, loaded.....no mods, yet!
