I have a 96 with a LUK it works fine all winter As soon as it warms up it slips the pedal loses all it free play and it slips, It is not over full and the vent is open in the cap any one have any input that may help on this?
Thanks Dave
Grass was not greener LOL Im Back to Ford
2004 F-350 4x4 Dually Lariat 6.0 torqueshift 4:10 gears.4 inch Exh. EGR Blocked off, other then that stock. 102K worth of extesive road testing done so far.
04.5 Dodge 3500 4X4 Dually QC 325-600 CTD 48Re auto.Tradeed for the 04 F-350
SOLD-99 350 CC dually for the Dodge [email]psdisel95@aol.com http://i68.photobucket.com/albums/i1...000_0441-1.jpg http://i68.photobucket.com/albums/i1...000_0439-2.jpg
Pull the clutch master cylinder pushrod eye off the pin and check alignment of the two. If the pushrod seems too long, shim the master cylinder away from the firewall with washers.
Ford has had some crappy engineering and/or crappy aftermarket parts that don't allow for adjustment or tolerance stack up.
Bill in sunny Tucson
Bone stock 94 1/2 DI turbo 4x2 F250, Rancho steering stabilizer to eliminate front end shake, sensor safe clamp mod, filler neck mod
Gun Control: The ability to consistently hit what you are aiming at.
Graduate, UA, Mech. Eng.
Im not sure if this would cause the problem, but are your hydraulic lines at any point coming into or contact or very close to any heat source like the exaust?
Thanks Guys I will take a look and see what I can Find, It'S funny how all winter it is fine even plowing snow but when it warms up it slips and all the free play goes away.
Sounds like a fluid expantion thing.
I believe we are all on the same track. If the pushrod is too long and the fill opening in the master cylinder is blocked off, thermal fluid expansion will create a slipping clutch. As the clutch wears, it gets even worse. Keep the fluid cool and save your slave cylinder seals. Then head for the fridge and keep your self cool.
Bill in sunny (@104 today) Tucson
