Old 01-12-2006, 02:52 PM   #1 (permalink)
97 3/4 to 1ton suspension
I have a 97 sc lb 250 PSD and I recently put a dana 60 under it. At the time i didn't know any better (lack of research) but i used the 250 springs and left the rear 250 blocks in. As you can imagine it rides teriable and even though it sits about level the rear could go up an inch or two. The rear springs are pretty much wore out I think since they are factory and hauled alot of loads (292,000 miles). I was wondering if there are different springs with different ratings like the super dutys have and what their part numbers are. I have the 4inch rear blocks. I was planning on all new springs and hoping i could get it sitting and rifing right. And hopefully not sitting to high (wouldlike to stay with 265s)
thanks for the info
Ted
TEDab is offline
Old 01-12-2006, 03:41 PM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: 97 3/4 to 1ton suspension
Dought if they are worn out. It is s truck and it is going to ride like a truck.
MarkEkberg is offline
Old 01-12-2006, 04:35 PM   #3 (permalink)
As far as I can find out you have the same springs as the F350's now. Also the same engine, trans, brakes, & even light bulbs.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 01-12-2006, 05:00 PM   #4 (permalink)
SlopeTruck's Avatar
My Photos: (29)
I would think you would get a better ride out of the 1 ton front springs and wouldn't have to worry about the pumpkin hitting the crossmember. That and using the 4" blocks would make it sit as high as a 1 ton. A RSK would give you a better ride but also lift it about 3".
[color:"blue"]WEBSHOTS[/color]
'00 F350 CC 4X4 longbed, wht, Lariet pkg. She's pretty! Open element intake, 4" exhaust, A-pillar pod w/ Isspro gauges, TW 4 pos. chip, leveling kit, 315-70-17 BFG AT's on black alloy rims, and...
SOLD '95 F350 CC 4X4 (ex-slope truck) flatbed. Open element intake, 3-4" dp, 4" straight pipe through bumper, shimmed FPR, IDM mod, TW 4 pos. chip, DIY RSK/shackle flip, 315-70-17 BFG AT's, H2 rims, 4.10's, rebuilt E40D, 3 guage a-piller pod w/ Isspro guages, DIY rear disks, SD front bumper, Warn 8000# winch, Explorer power buckets, Dodge center console/seat...
Play/plow truck '81 F250 on 40X17's. Bored 351W, S/C bobbed 3', 4 wheel discs, solid axles, Detroit, 2 winches, lots of DIY stuff.
Commute Vehicle: '07 American Lifan LF200GY, 1 cylinder, 16 hp, street legal enduro bike of Chinese origin. Top speed= maybe 70 mph but gets 80 mpg
SlopeTruck is offline
Old 01-12-2006, 08:09 PM   #5 (permalink)
If you really want to go for a beter ride, go for SD front springs with a shackle reverse, and use SD rears. To use the SD rear springs, you have to drill out the holes for the spring eye bolts. Look for a guy lifting his Super Duty to get the springs. Do a search or check out CaryT, and several others for details.
Yes, springs do wear out. Also interleaf rust makes for a worse ride.
Also there are 3leaf and 5 leaf rear springs. My 96 F250 has 3 leafs in the rear plus the big bottom overload leaf. My 91 F250 has 5 leafs plus the bottom overload leaf.
I have also had sucess turning the bottom overload leaf over so it comes into effect later. I wouldn't do this if you haul heavy (unless you have air bags. It could make wheel hop worse, but I havent seen it (YET)
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 01-16-2006, 12:34 AM   #6 (permalink)
What does the superduty springs do for our trucks? is it that much of a difference between the two?
03 F250 SC LB 4x4
4.5 inch DR kit. 35's
Freeflowing 4 inch lol
In SO-CAL?
Check out Southern California Powerstrokes.(SOCAPS).
desertwheeler is offline
Old 01-16-2006, 12:50 PM   #7 (permalink)
Ask Caryt or just go ride in a 99 to 04 Super Dooty. The rear springs help a little, but the big change is the front. The SD springs are 4" longer and thus more flexible.
Old 01-16-2006, 08:33 PM   #8 (permalink)
do they lift it more? how do they fit in the front then?
03 F250 SC LB 4x4
In SO-CAL?
Old 01-17-2006, 02:04 PM   #9 (permalink)
The stock SD springs have about the same arch, but the process of putting on the brackets and reversing the shackle system so that the shackles are at the rear of the front springs where they work like they should raises the truck about 2.5 inches over the stock F350 hieght or 4 inches over the stock F250 hieght. Do a search on member caryt, and on shackle reverse. Cary has photos of the brackets etc. Go to offroadunlimited.com and skymfg.com (might not have the second one exactly right)You will learn how to set up out trucks where they ride very nicely.
