will the 99 abnd up hpop work with my truck...i was wondering about the drain back issues....and what would the fix be for it to work on my truck
thanks....
05 F 250 XLT extented cab PSD, guages, exterior stuff, recon stuff, SCT Xcal 3 innovative X street tune, silver line cool duals, mtx thunderform encolsure with two 10's, alpine deck.
96 F250XLT heavy duty, ext cab, PSD 5-speed, 4:10's/limited slip-so far homemade tymar intake with big filter ,diy stage 1's, ts 6 pos chip, 4 inch turbo back to 5 inch slash cut stacks, pyro and boost guage.reverse glow guages, replaced clutch with a LUK replacement,garmin street pilot, sirius sat radio, Alpine Cd player, Alpine Type R 12" sub, sony xplode amp in custom center console, diamond plate trim and side steps, Visor, bug sheild,
A 99.5 hpop is a direct replacement for the one you have. The only differance is the late model is a 17 degree pump and your 96 has a 15 degree swash plate. The new pump will have quik connects for the high pressure oil lines and you will have to remove them and reuse the fittings from your old pump. Everything else is the same, even the gasket.
All the OBS PSD's and the early 99 SD's had the 15* pump. 99.5 and later 7.3's have a 17* pump. And yes, because of the longer stroke they do flow more oil.
with bigger injectors and/or extreme tuned chips the pressure from the pump will drop and throw a check engine light for low pressure. this is just a bandaid til twin pumps.
97 Black CC F250 4X4 BDP stage 2's D66 5"exhaust Snow H2o/meth shimmed FPR modded pedistal 17*HPOP tymar intake black bird rear disks HPX BTS Tranny 10/4/07
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SVT</div><div class="ubbcode-body">with bigger injectors and/or extreme tuned chips the pressure from the pump will drop and throw a check engine light for low pressure. this is just a bandaid til twin pumps. </div></div>
Cool, Thanks!
'97 CC LB SRW, Tymar, 3" DP, 4" pipe, SuperChip, air bags and a 36' GN that's kickin' it's butt
4x4Him.org, Tornado Alley Cruisers, White Trash of the Elwood Chapter, TLCA.org, IH8MUD.com
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">i was wondering about the drain back issues....</div></div>
The drainback issues only are a problem on '95 and older trucks. You will be fine.
If you can get a good deal on a SD pump, go for it. even with stock engine, you will get better throttle response and possibly better (marginally) mileage.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: radarman</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">i was wondering about the drain back issues....</div></div>
The drainback issues only are a problem on '95 and older trucks. You will be fine. </div></div>
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: wbones9</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: radarman</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">i was wondering about the drain back issues....</div></div>
So is there a fix for 95 and older trucks? </div></div>
In the sig of the poster you quoted, he has a diy mod hyper-link for the anti-drain back issue.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: STurbo90</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: wbones9</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: radarman</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">i was wondering about the drain back issues....</div></div>
Or you can use an external accumulator
Or you can change to the newer front cover. </div></div>
I have been down all three of those roads.
- The timing cover mod is by far the easiest and least expensive. You can do it in about 2 hours. One note, when you make your custom o-ring for the new standpipe, go EASY with the RTV. Too much RTV will push the oring into the standpipe and possibly block it. Yep, did it myself. I should take a picture of the darn thing. Caused a lot of grief trying to trace down a slow leak at the HPOP/timing cover seal. I saved it for posterity and it is sitting on my bench in a prominent spot.
- External accumulator tank. I had some left over stuff from my vette and was going to use it on the truck. Ended up not doing it because I could not locate a good spot for the tank. Good design tho. I have the electronic valve for it as well, just never installed it. Be prepared to spend $300 or more to get-r-done.
Front timing cover. When I pulled my motor, I went ahead and replaced the front timing cover. You have to replace the pan and oil pickup tube as well. Ended up costing me 300 in (used) parts. This is the best solution but can only be done with the engine out. Plan on helicoiling the HPOP threads while you are there, much easier to do with the cover off the engine and laying flat.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SVT</div><div class="ubbcode-body">99 and up pumps push more pressure </div></div>
More flow, same pressure capabilities...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
