Old 08-27-2008, 08:54 PM   #1 (permalink)
Question ABS light stays on
Hi Guys I've had my TS 6 position in my truck for about a month and a half now and today after a hard brake application the ABS light came on and won't shut off I tried leaving the batteries disconnected for about 5 min but as soon as I get over 25km an hour the light comes back on the speedo still works so I'm guessing the sensor is fine has anyone ever run ito this before I don't think it's a chip problem and was just wondering if I can still hook a snap-on scan tool to the truck or if the chip will effect it also what could the problem be if it's not the sensor any info would be greatly appreciated. Thanks
1996 Ford F350, CC, LWB, srw, 5spd manual transmission, 6 inch skyjacker lift with SKY front shackle reversal kit, 37" interco truxus on american racing rims, 2001 F350 intercooler, K&N cold air intake, stage 2 injectors, D66 turbo, 3 inch down pipe with 4 inch straight pipe with5 inch tip, TS 6 position chip(Beans Tunes), auto meter pyro and boost gauges, gutted EBPV shimmed FPR, and modded IDM.
squamishF350 is offline
Old 08-29-2008, 08:09 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Probably not chip related. Don't discount the VSS being bad. When my VSS went out, the speedo would still function (so it must not have been completely out). Same as you, the ABS light would come on once I hit a certain speed. I did all the wiring checks per the manual. After changing the VSS, all was good. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 09-03-2008, 10:52 PM   #3 (permalink)
I've got a 96 F 350 dually, I just put a new jasper trans in it and was driving it when it started shifting eratically and the abs light came on so I called my trans man he told me to replace the speed sensor on the rear end, It seems that it also controls the abs light. I did it even though my speedo was reading correctly with doubts but it worked. No abs light and no more eratic shifts that was last month and about 5,000 miles so far and no abs light again.
96 F-350 SuperCrew Dually,Hypertech programer, BD Performance Exhaust Brake, Taylor Wing, Stainless Trim and Running Boards, Trans Flow Systems Aluminum Diamond Plate 100 Gallon Auxillary Fuel Tank, Jasper Transmission, Billet 1800 stall converter running 2 trans coolers with 3/8 braided cooler/trans lines.
jcarter8968 is offline
Old 09-10-2008, 11:52 PM   #4 (permalink)
hansvl's Avatar
Don't forget to check the blue fuse you can only see when looking up at the fusebox.
94 powerstroke 5 spd, 4x4 xcab longbed,5 spd, 189.000 miles 4.10 gears, tymar style open intake, 3" DPPI downpipe, South Bend clutch, Edge EZ,pyro gauge, 1" front lift, Firestone airbags rear, 285 Toyo a/t tires, BB in fuel regulator
http://good-times.webshots.com/album/55769610
Go to my albums.
hansvl is offline
