Let me start this discussion by saying I have nothing negative to say about any of the builders of performance injectors. I believe they have done a lot to improve the PSD performance world. For most people any of the injectors on the market are a great buy. I know the builders work very hard to keep prices down.
For me personally, I would rather have brand new injectors. My past experience and my personal preferences make it worth the extra $ to me, up to a point anyway. It is cost prohibitive to buy new injectors, then pay to have them modified. However, If AC codes out of the box will perform as well as Stage 1 150 to 160cc injectors, I would go this way.
So the question is...does anyone have actual info on AC code cc rate, and do they use the same tips as Stage ones? Any reason not to do this? I'm going for a mildly built daily driver that gets decent mileage, doesn't smoke excessive unless the chip is in extreme, and lasts a long time.
Diesel Mechanic 28 yrs
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems Stealth Dual HPOP Systems Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
don't mean to be a nit-wit, but AC= what?
I believe they are talking about AC code injectors. These injectors were used in "high torque" T444E engines. That's our motor but International calls it the T444E.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
Well actually ya I do have some flow rates more or less. The piston in the AC injectors is the same as in the AB injectors and the plunger and barrel is a single shot like an AA injector. SO that being said when I flow tested an AB injector with an AA P&B that would essentially be the same as and AC and it flowed 155cc. I just happen to come across that spec when I was looking through some of my notes today.
but the problem with new injectors is they cost more and you wont get the same customer service as you would if you were to buy from BDP
That's only part true. Yes it will cost more but you can find just as good of service elsewhere as well! [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
The piston in the AC injectors is the same as in the AB injectors...
FYI, the AB and AC Pistons are a little different: The AB flows 155cc's, the AC flows 160cc. I have both of them next to me, they are different, just so ya know.
Now to answer the question the poster asked, if you want NEW injectors AND more performance, the AC's will drop right in and get you 160cc's of flow.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
97 F-350,XLT, 4-dr, auto, 270xxx mi, Geolander A/T's, 4"exhaust, no ebpv, 203* t-stat, electric fans, lunar gauges, amsoil nose to tail, custom weight bracket and hitch for pullin, diy intake/air filter, hpx hose, LED cab lights, extra fuse panels, kenwood stereo system, pedestal from Rick, 4r100 out of an '01, trans mods from Jon, custom big fuel system, arb's front and rear, and 6.0 i/c, custom big oil
What's different about them? According to my paperwork from Dipaco the AB and AC pistons are the same part number and everything. They are both 29.7mm makeing the AC a 155cc injector just like I tested the AB with single shot P&B.
Looks like different part numbers to me???? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Looking at the pdf to which Keven linked, it looks like everyone is sorta right. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
The AB and AC Intensifier Pistons have different part numbers, DPS13050/31 and DPS13052/31 respectively but are the same length, 29.7mm.
Now why the different part numbers and exactly what is different, I have no idea, nor do I claim to. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Holiday Cheers from Orlando, FL! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dave
__________________ 1996 F-350 XLT CC SRW 4x4 with plenty o' Redneck Bling: APCM●BTS-E4OD●4L10●MADDOG injectors●Hypermax H2E, intercooler, & exhaust●TYMAR intake & HPX●TSM disc brakes●Hydro-Boost●International water pump●215 amp generator●CCV re-route●285/75R16 Wild Country XTX tires●Centramatics●Denon DCR-830RD & DCH-520 203,000 happy miles DZLJIM 3:16 ~~NTxPSA - Hold my beer and watch this.~~
The triva question for yall injector guys is HOW are they different if they aren't differnt lengths?
Yeah! Winner gets a six-pack of Shiner Bock, courtesy of Big K! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/tongue.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Dave
Dave
