Acceleration Problem - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-21-2008, 02:00 PM   #1 (permalink)
31catdr26's Avatar
Send a message via AIM to 31catdr26
I have the 6pos bully dog chip and on the high setting the truck acts like it is derating/cutting back when it gets around 2000rpm(Has done this since ive had it).When you let off the throttle a little its fine also it doesent seem to have as much power as the chip on the other settings It has a new fuel pump,re-sealed injectors (a week old) and i just am a little stumped whether it would be the chip which i have taken off and made sure the connections are super clean or whether it might be the heui pumpitself the injection control valve and the sensor is about a year old im gonna get a hold of a scanner this weekend but im wondering what you guys think. Thanks alot for any suggestions/comments
31catdr26 is offline
Old 11-23-2008, 02:54 AM   #2 (permalink)
The stock injectors you have might have something to do with it.Just a thought.
1997 F250 XLT CC PSD E4OD 4.10LS (AB CALI Truck)
3" down pipe
18k mod
DIY intake
2" leveling
egt,trans,boost,water,oil,oil temp,volts
Cat delete
1996 F250 XLT EC PSD E4OD 4.10LS (AB CALI TRUCK)135K
DIY intake
DB exhaust brake
HD trans cooler
ono_55 is offline
Old 11-24-2008, 08:18 PM   #3 (permalink)
CVB Fireman's Avatar
i had the same problem it was the clutch slipping
NEW BABY- 2005 Chevy Duramax Diesel CCSB.... 8 inch fabtech lift 37 inch mickey Ts on 18inch flat black pro comp Rims. Edge Insight EFI!, straight exhaust. AFE intake and turbo inlet. EGR blocker plate Fully loaded Pioneer DVD double in deck. 2 12 inch shallow fosgates... sorry i switches guys but this thing is Bad To The Bone.
f-350 4 door long bed. 6 speed. 5 inch stacks. 9 inch lift. 40 inch Ground Hogs. custom Front and rear bumpers with 10,000 Warn WincheSSSSSS.K&N TW chip, stage 1s, IDM mod, exhaust brake. limo tint. peterbilt cab lights. dvd screen 2 shallow fosgate 12s (sick!!) and everything else you can think of. damn ive spent way to much money on this truck.- newest smartest and awesome edition is a set of custom built track bars. should have gotten these from the get go
CVB Fireman is offline
Old 11-24-2008, 11:56 PM   #4 (permalink)
johndeerebones's Avatar
Sounds to me like the chip is calling for more pulse width than your truck is capable of, in short youre running out of hpop oil, the stock pump can't keep up with demand. When it "derates" keep you foot in it for an extended period of time, after 15 seconds or so you will throw a code, bet its a P1211. These older trucks can't flow as much fuel as some chip manufactuers try to get out of em. Completely unhook the chip and drive it and see if it still does it.
If this is the problem, you can install a hpop off of a SD and get a little more hpop oil.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
