Adrenaline installed - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-28-2009, 12:28 AM   #1 (permalink)
Got my adrenaline hpop from ups this morning so I went right to installing it. Install went real well, probably like 2-3 hours. Had some trouble getting it started though but I called Bob and he talked me through, I had reused my IPR as it was not very old but my ipr o-rings must have been bad because they were leaking oil not allowing pressure to build up enough. Pulled the ipr back out and installed a new generic o-ring that was about the same size and then it fired right up. I find that it starts a little faster and accelerates easier/smoother. I'm hoping my mileage will improve some but haven't driven it enough yet get a good reading on that yet.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 08-28-2009, 06:49 AM   #2 (permalink)
ammayernick's Avatar
Congrats man! You will definitely pick up mileage as well as quicker throttle response and power. Extreme difference while towing.
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps * http://community.webshots.com/user/ammayernick
ammayernick is offline
Old 08-28-2009, 08:44 AM   #3 (permalink)
Sure makes me wish for one...I hope to be towing my trailer down to Florida in a few days and every bit of towing power helps.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
Old 08-28-2009, 09:18 AM   #4 (permalink)
When I ordered it, the website said it would be at least two weeks before it got sent out. I filled out the info late Friday night and Monday morning I had an email that the pump had been shipped and should see it by Thursday. I was surprised. Also, the price is going to go up on the pump by Sept. 1 so I wanted to get it ordered by then at least.
sdan27 is offline
Old 08-28-2009, 09:35 AM   #5 (permalink)
Cratos's Avatar
My Photos: (15)
just got mine and hope to install next week. and the HPOP filter to.
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
Cratos is offline
Old 08-28-2009, 10:02 AM   #6 (permalink)
I'm waiting for cooler weather to install the reservoir filter as well. Awesome mod to have .....will save on dirty IPR's.
Old 08-28-2009, 11:57 AM   #7 (permalink)
How much is the price going to go up?
edit: nevermind, their web site says its going to go up to 589.
Looks like I'll be maxing out my credit card this weekend...again....
coming soon: 6.0 IC
Old 08-28-2009, 12:25 PM   #8 (permalink)
Squid63's Avatar
Send a message via AIM to Squid63
I got mine yesterday, now I just need to finish assembling the engine that it's going on. I have high hopes for this pump based on all the reviews I've read.
94 F250 Supercab 4x4, 7.3 IDI Turbo, NV4500 5 speed, 4.10s
95 F350 Crew Cab 4x2, 7.3 DI, ZF 5 speed, 3.55s
Squid63 is online now
Old 08-29-2009, 07:47 AM   #9 (permalink)
Ordered mine this morning, can't wait!
1997 F250 - some stuff
2006 Mazda Speed 6 - stock except for satellite radio
aint no 6-0 is offline
Old 08-30-2009, 08:29 PM   #10 (permalink)
ckjneil's Avatar
running stage 2's and stock turbo etc how much difference will the after market HPOP make?
1997 f250hd 4x4 Ext Cab LB, 5" custom stacks, mbrp down pipe, Bean's Diesel 6 pos chip, Rosewood Stage II's, 35"x13.5 MT Baja Claws on KMC Rockstar 18" wheels 1.5"wheel spacer/adapter, DIY TYMAR styled intake, BD Power Turbo Thruster II
Previously Owned: 2006 F350 CC SB, Airmax Intake with KN, Quadzilla Adrenaline with Pulse Monitor, HID Conversion, Recon Smoked Mirror lights, 2.5" level kit,
Same wheels and Tires on my 97 above,Soundstream DVD
ckjneil is offline
Old 08-30-2009, 08:36 PM   #11 (permalink)
if you look on the dieselsite page, it says the only thing it won't help with it the code B injectors. it says it is designed especially for hydrid 530 injectors and large stage IIs. should be an 80 horse increase with the stage IIs and aftermarket programming.
sdan27 is offline
Old 08-30-2009, 09:20 PM   #12 (permalink)
78Ford's Avatar
Still lovin mine! Worth every penny. Truck starts faster and has better throttle response. I am taking it on a 1200 mile trip this weekend and look forward to mpg figures. My goal is to get to the 20+ neigborhood.
1995 F250 4X4 F350 Conversion 648,000 miles! 7.3L, Dana 60 swap, Front & rear sway bars, ZF6 SIX SPEED Swap!, NV271 Transfer case, 4.10 gears Supercab. Superduty starter with 4/0 battery cables. Bean's tranny savers,Adrenaline HPOP,Wicked wheel, 1.0 A/R housing, TS 6 position chip, 3" downpipe, Gutted EBPV, Modded pedestal, SD fuel heater mod, FPR shim mod, IPR rebuild, 250 amp glow plug relay, APCM, Throttle pedal mod, 99' IDM110, Autometer pillar pod w. Sunpro gauges. Hydroboost brakes, New front springs.
1997 F250 Crew Cab 4X4 Mint Beauty. 201K miles Automatic 3.54 ratio all stock except for Stancor glow plug relay & FPR shim mod.
1978 Bronco. 1991 460 EFI. Frame off restoration. 12mpg and NO MORE carb issues!
78Ford is offline
