Old 01-12-2007, 03:28 PM   #1 (permalink)
My Photos: (32)
Aeromotive fuel pressure regulator boost reference line.
Is it possible to have a runaway engine situation if the diaphragm ruptured in the Aeromotive regulator?
I have found a performance gain when boost referencing the regulator in addition to a base pressure of 60-65 psi. I also used a very small orifice in the boost reference line. I just wonder if the engine could tach out to the point of damaging itself in the time it took for the fuel pressure to bleed down after shutting the key off.
Any thoughts?
God Bless,
TC
Afterthought: If you are running the boost line to the regulator, what base pressure are you running? I noticed someone else runs a lower base pressure with the boost reference...
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
Old 01-12-2007, 07:38 PM   #2 (permalink)
Ford_Forgotton's Avatar
Send a message via ICQ to Ford_Forgotton Send a message via MSN to Ford_Forgotton Send a message via Yahoo to Ford_Forgotton
Re: Aeromotive fuel pressure regulator boost reference line.
The instructions that came with my ITP fuel system was to not use the boost reference port.
In fact, they include a "blowdown" line to run from the boost port, over the engine, and down to the fenderwell.
The boost reference diaphragm has fuel on one side of it, and if it should rupture, fuel would spray out the boost port. The blowdown line is therefore needed as a safety to direct fuel away from the motor.
Daryl
Forgotton.net
Northwest Ford Diesel Truck Club
2000 F-350 CC SB 4X4 SRW BONE STOCK!
Ford_Forgotton is offline
Old 01-12-2007, 11:57 PM   #3 (permalink)
My Photos: (32)
Thanks Daryl!
I know Aeromotive's website says to route a hose to a safe dumping location if you don't boost reference the regulator too.
TC
On Edit: I jacked the fuel pressure about 5 psi and hooked up the boost reference at the same time and got nice results. Maybe I could get by with just the higher fuel pressure... something to try!
TimC63 is offline
Old 01-13-2007, 12:12 AM   #4 (permalink)
Tim, if the boost reference being hooked up makes a difference, then you must have a fuel delivery problem somewhere. You may want to get a mechanical gauge on the system that you can see while driving. If your pump can maintain 60 psi to the injectors that is all you will ever need, more pressure can not physically cause a performance gain, the injectors just don't work that way.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 01-13-2007, 12:19 AM   #5 (permalink)
I agree, the boost reference line should have no effect on our diesels. Look at delivery issues instead, such as feed lines, and pressure drop off at higher RPMs.
I bought an autometer 0 to 100 electric gauge, that uses a sensor that looks very much like an ICP sensor (same plug in fact!) and monitor my fuel pressure in the cab.
I can drop my pressure to almost 40psi at WOT in first just before it shifts to second.
Daryl
Forgotton.net
Old 01-13-2007, 12:25 AM   #6 (permalink)
Daryl, is this a hardline or a hose? This is a great safety idea!!!!
Old 01-13-2007, 12:26 AM   #7 (permalink)
My Photos: (32)
Thanks Pat and Daryl!
As I mentioned, I upped the base pressure from about 58 to 65 psi at the same time I boost referenced it. I will see if I can get by without the boost line, as the increased fuel pressure may have been all I needed.
Regarding monitoring the fuel pressure, the UPS truck delivered my digital gauge and senser from Dakota Digital today! I will get it temporarily installed tomorrow so I can watch fuel pressure on our trip to Ocean Shores. Unfortunately we aren't taking the trailer, which puts the real load on the ol' Stroke!
TC
TimC63 is offline
Old 01-13-2007, 02:09 AM   #8 (permalink)
No trailer? Looks like you will have to improvise a load by using fast acceleration and high top speeds [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 01-13-2007, 02:25 PM   #9 (permalink)
My Photos: (32)
[img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
Hahaa, while I do agree that is the universal answer in most all cases... (rates right up there with if it ain't broke fix it til it is..) the wife doesn't appreciate that when we have all the kids on board, plus we still have some packed snow and ice on the roads up North of Seattle! We are up to a balmy 25 degrees today!
Take care!
TC
TimC63 is offline
Old 01-13-2007, 03:21 PM   #10 (permalink)
DIESELDUTTON's Avatar
I know you might not need it anymore but, I work on boats and some boat builders use a electric anti siphon valve in the fuel system , when the ignition is powered up the valve opens, its probably overkill but could be used it would also have to be reduced from 1\4 npt.
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 01-14-2007, 12:49 AM   #11 (permalink)
Its a very stiff plastic line. Tiny. Barely fits over the nipple of the boost port. Its just there to direct any POTENTIAL fluid away from the motor. Its not much different than boost gauge tubing, just black, and large enough to get over the boost port.
Daryl
Forgotton.net
