Anyone have any luck with after market valve bodies for our E4OD's ? My trany is holding gears fine. But after installing my BDP stage I's, the shift's are sloppy. I've done the only mod's I know of (see sig.), but I'm wondering if a complete valve body change will do anything to help ?
Chris
P.S. I know, I know, a call to BTS is in my near future [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img]
1997 F-350 CC PSD 4X4/4" Softride/Weld Super Singles/35X12.5 BFG MT's/RS 9000's/Hypermax downtube/300MAX chip/Bean's stage I injectors/4" straight pipe/EBPV guts removed/shimmed/Auto Meter Pro Comp pyro & trany temp guage/exposed K&N cone/52,000 lb. trany cooler/tricumulator springs/sonnax valve/4.10's
"Horsepower is like hamburger, you can buy as MUCH as you want",
"If cool were cheap, everybody would be"
Your Sonnex kit is probably just as good as any other valvebody mod you find out there. If you want to help yourself out a bit you might do a heavy duty TC. The E4OD TC is simply junk.
1995 F 350 CC PSD 4X4, 4.10's with E4OD. DIY open element air intake. DPP Downpipe. 10K mod, Fumoto drain valve, SCMT 1705, Shimmed FPR, Stancor GP thingy. BDP Stg I's. Panasonic HU feeding an Orion 800.2 for the two 12" JL's and an Orion XTR400.4 for the Infinity 6.1's Yeah its a diesel but I cant hear it from inside the cab. 5 " open exhaust is installed, she barks now! Isspro Trans,Pyro & Boost on the A pillar. Tru-Cool 28,000# stacked plate trans cooler. bdp Stg I's and a UCC TC and Trans-go Tugger kit to hold it to the ground.
Purchased 9/29/03 @ 108,000 mi
As of 12/25/05 its @ 160,000 mi
Upcoming mods- ?
Also play with a '65 Mustang "ground upped" and a customized 92 Harley. Life is good.
One reason I've stayed away from bigger injectors and a chip is my stock transmission and torque converter. You might be wise to upgrade your torque converter and put in a Transgo Shift kit. If you plan to tow heavy load add a Transgo Hugger Kit to the list. Just my opinion though...nothing else [img]/ubbthreads/images/graemlins/phoney.gif[/img]
95 F250, 4X4, E4OD, 4.10, Hypermax DP and Tymar 4" Exhaust System, Tymar Air & Coolant Filters and HPX Kit, Tymar fuel fill mod, External Transmission Filter, Schaeffer's ATF. Add-a-leaf, Redline Differential gear oil and Redline ATF in Transfer Case. OilGuard By-pass oil filter. Schaeffer's 5W-40 in the engine. A-Pillar...Autometer Boost, Pyrometer and Trans. Temp. Gages, Under dash...Oil Pressure and Water Temperature gages, 1705 Superchip Tuner, Stancor GPR, Factory Tech Valve Body, Evans Waterless Coolant, Two 4590 Tru-Cool Transmission Cooler in series, Explorer Overhead Console, Diesel Turbo Lifesaver, Tymar Fuel Filler Mod.
Here is the Tugger Kit by transgo...... also if you contact Richter69 (he replied about three posts up) he can set you up with what you need for TC and shift kit.
Upcoming mods- ?
the std HD2 kit is fine for almost all applictions, the tugger kit is geared more towards towing with additional valve body work which should really be left to a pro to install, teh reg HD2 kit si easy enough to do your self as it only is the accumaltor body, if you go into teh valve body itelf you must move or replace balls in there, which is hard to do upside down.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
