Aftermarket additional lighting on front of truck...
Just wondering if any of you have an photo's and a description of what you might be using for additional lighting for night driving! I just haven't seen anything recently as to what I'd like to add, so I thought I'd see what some of you folks use for this purpose.
Re: Aftermarket additional lighting on front of truck...
i have the piaa driving/fog combo. got the fogs tied in with low beams and the driving lights come on with the high beams. i really like them. i dont have any pics though
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
Check out pix in link below.
LightForce are nice as you can change lenses pending what your needs are and they are a good light for the $$$. VisionX are VERY bright as they are true HID and the nice thing is the ballasts, igniter is all in the light housing, makes for a quick install compared to other HID setups, albeit pricey. The combo I am currently running are LightForce 170's Blue combo filter and VisionX 8500 with Euro lenses.
This combo is NOT street legal....but much better then taking a Moose in the face.....mine are hooked to a relay (one relay per light). The relay trigger is ran through rocker switch on door (that lights when the "Aux lights are activated")then through a foot switch on floor.
cheers,
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff. http://community.webshots.com/user/jcart44
I run the procomp light bar with 2 Hella 8" 100w
95 F350 cc, 4x4, 5sp with a short shift kit, 3.55LS, D66 turbo, Beans stage 1's inj, modded ped, IDM mod ,hx mod, DPR intercooler, 3" intakes 3" dp, 4" side out, 2piller w/boost&pyro, steering column mount w/hpop gauge, TW chip, AFE stage 1, ccv mod, DIY oil & coolant filter setups, John Deere coolant eye, ORU RSK, Black Centerline wildcats w/Hankook RT03 315-75-16 mt, One day hope to have a RockDog front bumper w/8" Hellas and a CT performance rear bumper/tire carrier, 05 SD front and rear seats.
Trying to find time to install Con O clutch, 17* HPOP Swamps fuel sys, Ford rear diff cover, Blackbird rear disc brake setup.
I have two Kids and they come first...
I run the procomp bar with 2 procomp explorer 130w lights, get the Hellas. I ran mine off the high beam switch with another switch to bypass them if I am on the "road". I can put the highbeams and the lights on when I need to or just the highbeams, Makes it easier to turn them off when opposing traffic comes along.
95 CCLB 4X4, DP, TYMAR, 5POS CHIP, 4",3 GUAGE POD, 115k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.
I run two KC daylighters (150 watts w/ stainless steel housing) that are hooked to the high beams through a relay. They have a reflective range of close to a mile and are good moose lights. 3 would be perfect for the best pattern but the 2 do fine. Best I believe unless you spend the big bucks and go HID.
Have the 5" Lightforce on my wife's suburban and they just don't work as well. The larger (9"?) Lightforce are what most of the big rigs around here run so that says alot for them. They pull less amps then the daylighters and you can change the lenses. On the flip side the daylighters are smaller, cheaper and have a warrenty so lenses/bulbs are replaced for the cost of shipping them to AZ.
__________________ [color:"blue"]WEBSHOTS[/color]
'00 F350 CC 4X4 longbed, wht, Lariet pkg. She's pretty! Open element intake, 4" exhaust, A-pillar pod w/ Isspro gauges, TW 4 pos. chip, leveling kit, 315-70-17 BFG AT's on black alloy rims, and...
SOLD '95 F350 CC 4X4 (ex-slope truck) flatbed. Open element intake, 3-4" dp, 4" straight pipe through bumper, shimmed FPR, IDM mod, TW 4 pos. chip, DIY RSK/shackle flip, 315-70-17 BFG AT's, H2 rims, 4.10's, rebuilt E40D, 3 guage a-piller pod w/ Isspro guages, DIY rear disks, SD front bumper, Warn 8000# winch, Explorer power buckets, Dodge center console/seat...
take it from a desert racer light froces are the best with there abilty to cange beam paterns and light colors with just the change of the face there all some
sorry about frequent miss spellings I'm severly dylexic
A true Desert Racer For life
1997 f250 4x4 ex.cab long bed 7.3l Scalzo Racing Chase 1
Airraid stage 2intake
take it from a desert racer light froces are the best with there abilty to cange beam paterns and light colors with just the change of the face cover there all some
Does anyone know how the "wattage" of lights...such as in 55W 130w
150w comes out with regard to the candlepower unit?
Years ago my brother had a truck with (what we called them then) aircraft landing lights, and boy they where superb! Don't know if I need that kind of lighting, but something that is perhaps double the intensity of the regular high beams!
Thanks..
Dale
IDM mod
TYMAR intake
Amsoil dual by-pass
Precision Ind triple disk Torque Convertor & Pro build tranny
Transgo Tugger shift kit
Ford AIC & full gauges
Mini-Me/SWAMP 250cc Hybrid 530 injectors
17° HPOP
5" custom exhaust
Superduty Intercooler & GTS pipe kit
CCV mod
TS 4 position Flip Chip
I cannot remember the model number of the PIAA's that I have, but they have a fiberglass frame (no rust) and I have 4 on my front bumper (they replaced some Hella 2000's that rusted very badly). The middle two are pencil beams that are aimed straight ahead and the outer two are called "Eurobeams" (I think), and the illumination pattern makes these perfect for aiming slightly off to either side. They came with 100W bulbs that I replaced with 130W bulbs just for grins. I am very happy with this setup, but they were not cheap. But I use them A LOT during the long dark winters here in Alaska and they have helped me avoid more than one moose! Pete
I run 80/100w xenon headlamps behind clear aftermarket housings, and that's just for starts. Mounted on the big bumper are two Hella worklight housings each holding two 55w halogen lamps, casting a very wide, flat pattern (great for lighting up the ditches and beyond to reveal deer, etc); there are also two rubber tractor lights whose lamps have been replaced with 100w GE aircraft landing lamps (#4509, if memory serves). These are very narrow beams, but very bright. All are re-wired thru relays with 12ga wire; the hi-beams provide the signal, and the lamps are fed directly. The net result is that when I flip on the brights I get 620w worth of evenly-distributed light (vs 130w thru OEM hibeams). It's daytime at night.
Josh
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 Toyo A/T (2nd set - got 55k from first set) on factory Alcoas, big front bumper w/4 really bright lights; F add-a-leaf, new alt x3, fuel pump, water pump, t-stat, fuel heater, vac pump x 3, PS pump x2, SD starter, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, 222k and counting...
I drive my '97 CCSB in southern Baja...where good lights are highly appreciated due to free range cows, horses etc. I posted here and got some great feedback.
I ended up going with a pair of KC long range 130w long range driving lights & a single Hella 150w off road light, both run via 3 way toggles and my hi beams;-) HOLY cow does it light up the night- I could not be happier. I see down the road at least 1/2-2/3 mile fully illuminated. Now I'm thinking of adding back-ups in the rear bumper to avoid the knarly cardons...
1997 F-250 HD 4X4 CCSB - TTB D50 - freshly rebuilt E4OD - 4.10
Tymar oil, open air intake & coolant by pass filter system(s) - Racor fuel filter - Bilsteins - BFG 285/75/16's Mud Terrains on Alcoa's - Hella long range driving lights, center mounted KC Off Road light with rear bumper mounted Hella fog lightswired for back up lights - Sony CDX-GT610UI CD/MP3/USB Reciever w/ iPOD interface - Garmin 600CSx
