Aftermarket Cruise Control - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 05-23-2007, 09:11 PM   #16 (permalink)
BlueMule's Avatar
My Photos: (12)
Re: Aftermarket Cruise Control
and then find the two wires that are black w/ a red tracer and brown w/ an orange tracer coming out of the Power Distribution Box, and make a jumper to connect these two?
It's even easier than that. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] Take a look at <u>THIS</u> picturs. On truck with factory cruise there is a pressure switch on top of the master cylinder that deactivates the cruise when you apply the brakes. Your truck wont have the switch but it will have the harness, it should be plugged into a dummy receptacle on the back of the underhood fuse box. That's where you need to insert your jumper. Just make sure that it is insulated because there is 12V going through it whenever the engine is running.
The pressure switch is a backup safety device in case the brake light switch on the brake pedal fails to cancel the cruise. Dont forget there is also an "OFF" button on the horn pad. If you wanted to make it just like the factory did it you'd have to replace your master cylinder with one with the port for the switch. I dont know of anyone that has gone to that extreme. I put the jumper in mine maybe 4 years ago because the switch was bad and leaking fluid. At one time I actually planned on buying a new switch and eliminating the jumper, finally last year I replaced the leaky switch with a bolt.
The harness is a good source for KOER 12V, I use it to power an hour meter.
BlueMule is offline
Old 05-23-2007, 09:21 PM   #17 (permalink)
Does anybody have a link to ebay where I can buy a horn pad? I keep looking but can't find any for sale. [img]/ubbthreads/images/graemlins/confused.gif[/img] thanks
1997 F250HD, PSD, Supercab XL, ZF 5 speed 4x4, Tymar intake running on B100
vaulter83 is offline
Old 05-23-2007, 09:35 PM   #19 (permalink)
Hey , Rodney,, Is it the 92-96 only?...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 05-23-2007, 09:49 PM   #20 (permalink)
BlueMule's Avatar
My Photos: (12)
Rick, I have factory cruise so never looked up the part numbers. It looks like our horn pads but I see it says for "E" series. I dont know if it's the same or not. I suppose <u>you</u> could crossreference the numbers on powerstrokeshop. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
All I did was look up the item number from a previous post.
Would this work for my truck....listing on Ebay is item # 150099571088
Yep, thats exactly what you need. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
BlueMule is offline
Old 05-23-2007, 10:48 PM   #21 (permalink)
Hey Rick, I just ordered one of those pads off of Ebay for my 97 F350. If you want to wait until I get mine I'll let you know if she's gonna work.
heinzboz is offline
Old 05-23-2007, 11:56 PM   #22 (permalink)
Sure! click <u>this</u> [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Thanks can't wait to add cruise control. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 05-24-2007, 12:10 AM   #23 (permalink)
BlueMule's Avatar
My Photos: (12)
Rick... It took me a while but I just figured out what you're asking. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I'm thinking that 97's would also be included as being able to add cruise to an XL truck but I can't say for sure.
BlueMule is offline
Old 05-24-2007, 10:11 AM   #24 (permalink)
Thanks Guys..
Rick.....
Old 05-25-2007, 06:31 PM   #25 (permalink)
galaxiedan's Avatar
I used the same auction part on my 97. I did notice that the wires on my truck werent the colors listed but it was the only connector under the brake booster that had 2 wires and wasn't being used. It was plugged into a small grey connector mounted to the side of the big electrical box by the booster.
1997 F250 XL 2wd 5spd 7.3 , SRW ,ext cab, Tymar air intake, 3"DP with 3" straight pipe, No cat or EBPV, "A" pillar gauge set with Auto-Meter Pro-Comp boost and Pyro, 265/75-16 with stock steel wheels, Custom conversion van bucket seats with custom console holding SFF PC with GPS and MP3
1990 F150 XL 2wd 5spd 4.9, standard cab (spare truck)
2005 Polaris Predator, Jardine pipe, K&N cone on carb, Dynajet jet kit, ACE nerfs, plus more!
galaxiedan is offline
Old 01-05-2010, 01:32 PM   #26 (permalink)
94-94 PSD Cruise control
I just did the cruise control mod on my 97 PSD and it works flawlessly. The mod took me less than 5 minutes to do. Thanks
powerstroke1997 is offline
Old 03-01-2010, 12:36 PM   #27 (permalink)
I just changed the steering wheel on my 2002 ford e450 van. It has a 7.3l. Where is the jumper need to go. The wire color and the location would be great. I have a wire plugged into the aux brake switch on the Master Cylinder already. I thought the extra switch on the Master cylinder should not be there since the van came without cruise. Where and I going wrong?
Dalemaz is offline
