Old 04-13-2007, 02:16 AM   #1 (permalink)
Aftermarket temperature gauge/oil leak
Hi guys, I have an after market temperature gauge that is wired into the fuse box. The problem is that when I turn on the fan the temperature jumps up about 20 degrees. I know this is interference but, I would like it to read accurately, where should I wire it.
My truck has never leaked oil until recently (after my last oil change) then it developed a small drip from the back of the oil pan (maybe). I just had my 5 spd. rebuilt and got it back on Monday, they said the rear main seal was not leaking and that maybe it was the turbo mount. The problem is that since I got it back it is leaking really bad! Any thoughts? Thanks, Mike
94 f250,5 spd,k&n air filter,77 Mitchel cabover,biodiesel - 95 Suburban 6.5 turbo - 87 Mercedes 300TD
bldrbiodiesel is offline
Old 04-13-2007, 02:36 AM   #2 (permalink)
Re: Aftermarket temperature gauge/oil leak
There are lots of places it can leak from up top.Check up top because it's probably coming down the back of the block and running down from the drain hole at the back of the valley.Good Luck,Calvin
1996 F-250 2wd, ext.cab,short bed,auto trans.,3:55 ratio,3 inch down pipe,4 inch stainless Magnaflow exhaust,"Baby Swamps",TS performance 4 position chip,Tymar air filter, coolant filter, and HPX hose.Autometer gauges(pyro.,trans.temp.,and boost),California FPR kit,gutted and plugged EBPV,ported hood & bug shield,203 Dieselsite thermostat, Extreme spray in bed liner,Wade bed caps,UAW black diamond plate under rail tool box,4R100 trans.pan & filter,LARGE Hayden trans.cooler,Diamond headlights,park lights and side marker lights,Mustang GT hood scoop,Clarion CD player,Kenwood speakers.Billet Torque converter,Extreme duty trans.build with Transgo "Tugger" kit.
Calvin1958 is offline
