Aftermartket turbo pedestal Questions??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 12-03-2008, 06:50 PM   #1 (permalink)
I have a 1996 F-350 7.3 and i was wanting to change the stands to the aftermarket OEM stand that is made for 1999-03s and i was wanting to know if there is anyway it will fit?
Firefighter3296 is offline
Old 12-04-2008, 12:31 AM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
I don't know if I understand the reason for doing so. Do you want to simply get rid of the EBPV actuator, etc? or are you wanting to move to the turbos used on those years? Or something altogether different? Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 12-04-2008, 01:02 AM   #3 (permalink)
yea i want to get rid of the EBPV actuator, etc. the reason im doing it is cause the pedestal is leaking oil a little bit and i need to replaceit.
Old 12-04-2008, 10:26 PM   #4 (permalink)
My Photos: (19)
You can use the EBPV-less International pedestal for our years (the later one won't work with our turbos):
Turbo Pedestal
(International) 1822873C1 (Non EBPV pedestal)
or you can modify a stock one as I did (pic in sig and another in gallery). Cheers!
Old 12-05-2008, 12:26 AM   #5 (permalink)
Jcart's Avatar
Depending where it is leaking you can also R&R it too.
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 12-06-2008, 09:04 AM   #6 (permalink)
What is R&R?
Old 12-06-2008, 10:56 AM   #7 (permalink)
My Photos: (19)
Remove and Replace (your original ... with new seals of course). Cheers!
