air ride kit - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 12-07-2008, 10:43 PM   #31 (permalink)
Originally Posted by BKB View Post
Poly bushings are not effected by oil and dont really dry rot but they do distort and split. I have used poly bushings in many locations were the factory bushings outlasted them by far. I would try and use a OEM bushing in the arms, even if they are spring bushings. That small amount of rubber will help absorb shock and vibration. And if this is the truck you haul that camper with then i would think you want comfort on long hauls.
By Z link are you talking about 2 parallel bars going forward and then a nother bar at a 45' between them, like the rear suspension of most drag racers? If that is what you are talking about i dont know how it even fit up front and strength would scare the hell out of me. Why not the topical radius arm with track bar. Its proven and works well.
The z bar design i am thinking is used on VOLVO trucks and with the design there would be no axle wrap and only one pivot point .
Jcart the heim joint was thought of too but they are noisy even if greasable but i havent totally given up on the idea yet ( of heim joint )
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 12-09-2008, 09:14 AM   #32 (permalink)
DZLJIM's Avatar
I would stick with poly bushing ends and not even consider heim-type joints. There's a reason oem has this type of connection (slide in bushing), not just on p'ups but semi suspensions, too. They just last longer, more durable.
Heim's shine where lots of flex is needed, off road and what not. But for an on-road air bag type deal I'd personally stick with poly bushing joints.
JMHO...
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-350, 4x4, CC Short Bed.
DzlJim.com for some redneck engineered projects.
DZLJIM is offline
Old 12-10-2008, 10:12 AM   #33 (permalink)
i agree hiem joints are un reliable
drford is offline
