Originally Posted by oldblue31
Will the Airdog fuel systems work on OBS trucks? Do we need to add anything else to them?We need a regulated return right?
At an educated guess level NO. May call them and see what they are rated for, but the Cummins fuel systems have a high pressure pump to, so the fuel systems for them only supply the high pressure pump, so they generally run less than 20 psi fuel pressure. Our engines on the other hand rely on the fuel pump to get the injectors filled in the small time they have to be filled, so our systems run atleast 50 lbs generally speaking.
Some of the fass systems are capable of 50 psi, but they also flow 200 gph which is WAY more than your engine needs, so the regulator will just let most of it go back to tank, the constant pumping will heat the fuel to an extent, you want a fuel system that is capable of your needs, but not too excessive. They are more expensive, but there are systems taylor made for your truck out there, try Beans Diesel Performance.
www.beansdieselperformance.com
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB
DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
