Old 05-14-2005, 09:36 PM   #1 (permalink)
Am I supposed to be able to get my nuts off with my fingers?
My spindle nuts were just finger tight is that normal? I am overhaulin the front end...it won't stop at this point. Now my rotors are cracked. Do I buy the drilled slotted from Napa? Will they make a difference for the extra $$. Autozone has rotors for $42.99 are they any good? It's a money pit at this point..help.
95 CCLB 4X4, DP, TYMAR, 5POS CHIP, 4",3 GUAGE POD, 115k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.
realbadlarry is offline
Old 05-14-2005, 10:12 PM   #2 (permalink)
ThreeStarJR's Avatar
Re: Am I supposed to be able to get my nuts off with my fingers?
[img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] only if you have a gentle touch! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]On two wheel drive tighten to 25 foot lbs. Back nut off 1/2 round. Tighten to 20 foot lbs. I'll look in the cd manuel for the four wheel drive....Haven't tried the a-zone rotors, but thier brake stuff scares me. Does napa have stock replacements? I seem to remember folks posting they have had good luck with them....
IN EDIT: Larry, while rotating the assembly, tighten the hub nut to 50 foot lbs. back nut off 90 degrees (1/4 turn) retighten to 16 ft. lbs.....you can tighten farther to get the lock key in....
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
#3
ThreeStarJR is offline
Old 05-14-2005, 10:54 PM   #3 (permalink)
According to the specs that came with my warn manual hubs tighten inner nut to 50 ft. lbs. while rotating hub to seat bearings then back off 90 degs.then tighten till the lock ring lines up with the pin on inner nut outer nut tighten to 160-200 ft. lbs. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Aric
96 F-350 4x4 regularcab dually 5spd 4.10LS [color:"red"]Home made Bumper[/color]DIY open air intake hypermax dp 4" exhaust DIY exhaust brake [color:"red"]Dump bed[/color]
93 F-250 factory turbo 4x4 extended cab [color:"blue"]MyPics[/color] 4.10 5spd K&N filter ATS outler and down pipe 3in exhaust to twin 5" stacks tweaked wastegate turned up pump LUK clutch boost and pyro and much more to come[color:"blue"]Mickey Thompsons classic II 265 75 16 Courser C/T[/color]
Ford makes it IH shakes it
Don't worry about the mule just load the wagon
93turbo'd_animal is offline
Old 05-15-2005, 10:55 AM   #4 (permalink)
rmyers2051's Avatar
A-zone and Advance rotors are inferior to NAPA, they have a higher silicon content in the casting, which is cheaper and also less friction. A local engine builder/drag racer built a turn-key drivetrain for a drag racer, after the build they could not get it to stop safely, put gauges on the master cylinder and according to Wilwood they were in spec for pessures,someone suggested asking the customer where he purchased the rotors. Turned out to be A-zone, swapped the rotors for NAPA units and it will now slide the front tires at 50 mph if they wish. Just their experiances, yours may vary.
F250Ext. 4x4 5spd. GV overdrive,4.10s,23+mpg
Bronco
Some people are like slinkies, Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs!
rmyers2051 is offline
Old 05-15-2005, 10:59 AM   #5 (permalink)
[img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]ROTFLMAO NOW THATS FUNNY [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1996 F-350 CC-LB-4x4, 4"Exaust,Custom Tranny w/billet TC, Banks I/C, Banks Transcommand,Banks Exaust Brake, Banks Turbo Housing, HM intake, 2003 Lariat Interior, 368500 miles, 4" lift+35's, 3 guage piliar + autometer guages, TS 6 pos chip. Warn tranzformer brush grard, Warn 9000i winch, Cepek off road lights. Pro comp trac bars, Detroit locker rear, ARB air locker front.
KurtPratt is offline
Old 05-15-2005, 05:38 PM   #6 (permalink)
lol made me wonder......
im running the napa lifetime guarentee rotors. i know some people that have had problems with slotted and drilled rotors cracking.
i havent had any problems with the napa rotors i like them
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
00 F350 4X4 CC
RIP CHRIS. 03/09/05
http://community.webshots.com/user/barebackjake
barebackjake is offline
Old 05-15-2005, 10:01 PM   #7 (permalink)
My Photos: (10)
yea you just have to squeze harder [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
<font color="red"> we are not here for a long time we are here for a good time </font>
<font color="blue"> MICHIGAN POWERSTROKE ASSOCIATION </font>check it out[img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
my picts
other toys
92 ranger extended cab with 310,000 miles
86 f-250 4x4 6.9 diesel 450,000 miles and still going strong
87 f-350 xlt 4x4 4 door 6.9 340,000
87 f-250 xlt 6.9 140,000
97 f-350 exteded cab 4x4 NATHAN P3 TRAIN HORNS two whipps, SWAMPED INJECTORS,head studs,cometic head gaskets, h2e turbo,lots of boost almost too much,joes idm, built e40d 4.10 gears,4 pos ts performance chip,open ellement air filter k&n #41-1400 hypermax 4in dp,kitty is in the litter box.10k mod shimmed,autometer gauges boost,oil pressure, pyro,trans temp, 6 in lift,6' traction bars, diamondplate toolbox, 5in stacks,lighted ford logo in the grill
smokinstroker is offline
Old 05-15-2005, 11:15 PM   #8 (permalink)
earnies2's Avatar
Thier your nuts personally I'd ask my wife for help!!!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
97 F350 dulie knapheid utility body 7.3 PSD 4x4 8611 LP BLIZZARD plow 8' ss sander diomd plate aulimiumn top boxes ladder rack whalen9004 strobe 6 under cover strobes on board air compressor air ride front and rear spin on trany filter 28 gvw trany cooler w/ fan modified ac condencer as trany cooler down pipe power windows and locks piller gauges piro ,bost ,top shelf incloods air pressure gauge trany temp strobe control, sander control and cb 83000 miles 2004 style headlights clear corners and turns plug in jumpers , grill painted to match truck visor over windshield.5" duel stacks,magnaflow muffler,ss simulators,8 way power leather buckets,2002 dodge console,water filter,5 electric fans,air Horns,215 amp altonator,gruip 31 batteries,tymar intake,5200 lbs rear springs http://community.webshots.com/user/earnies2
earnies truck
earnies2 is offline
Old 05-15-2005, 11:45 PM   #9 (permalink)
That is a question you're going to have to answer without my help. I've never actually had mine off so I'm not sure how you go about it but I can say that I hope I never get to the point where I actually have to contemplate taking them off.... It seems like at the very least, it would mess up your balance or something........
Mike
<font color="red">FIRST PICS OF MY WRECK,</font><font color="brown"> THE DESTRUCTION OF A FORD DUALLY,</font><font color="red">[img]/ubbthreads/images/graemlins/frown.gif[/img] ARE BELOW IN "My Pics"</font>
1996 F350 XLT crewcab dually, pullin a 50+3' step deck
1996 F250 XLT crewcab (wife's), pullin a bed full of milk meters and a 27' 5th wheel
<font color="aquamarine">My Pics</font>
<font color="blue"> I PREFER DANGEROUS FREEDOM TO PEACEFUL SLAVERY</font>-Thomas Jefferson
<font color="blue"> Remainder of signature deleted for political correctness violations</font>
RopinandRidin is offline
Old 05-16-2005, 03:36 AM   #10 (permalink)
my buddy take his off and leaves them with his wife until he really needs them
2001 F-350, Powerstroke, 4x4, Regular cab, Autometer Z-Series Guages Pillar mounted, DP-Tuner Stock, 80hp, 120hp, Quadzilla Green Filter Intake, BTM, Zoodad, HX Crossover, Wicked Wheel, Shimmed FPR, Geno's Garage Bling-Bling tailpipe, 295/75/16 TOYO Open Country A/T's, Leer Cap, Bedrug, Pioneer AVIC D3, JL Stealthbox, Rockford Fosgate AMP
1988 F-SuperDuty, 7.3, ZF-5, flatbed, converted to 4x4
1991 Ranger 4x4, 5.0HO 335rwhp
Downeaster, 10,000 dump trailer
dsldandually is offline
Old 05-16-2005, 03:28 PM   #11 (permalink)
This is one of the best titles I've seen in a long time.
Pat
06 F350 4x4 XLT, CC, LB, True Blue, 3.73LS, dash mount Pyro (ESOF knob), with stick, 23K miles, Toyo Open Country MT 275/70/18/E.
97 F350 4x4 XLT, CC, 136k.....SOLD to new owner
GOPDiesel is offline
Old 05-16-2005, 03:39 PM   #12 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
LOL [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]...wonder when this thread is gonna be killed
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille,
318hp 643tq
#24
sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
PSDan000 is online now
Old 05-16-2005, 04:08 PM   #13 (permalink)
Depends on how much I've had to drink [img]/ubbthreads/images/graemlins/blush.gif[/img]
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 05-16-2005, 10:48 PM   #14 (permalink)
Sounds to me like he needs to call Dr. Ruth......
Mike
Old 05-16-2005, 10:58 PM   #15 (permalink)
johndeerebones's Avatar
Oh man, I came in the post cause thought it was a good title to flame, but I see I've been beaten...quite a few times [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
HILARIOUS
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
