I've been bugging to do this for awhile now and so far the cheapest price I've found is from advance auto for ~$380. Tried ebay and rock auto among some others. Anyone else have any ideas. To those who have done this recently, how much did you pay and where? I'm not interested in a rewound 3G so dont bother with links to any.
Jason
'96 F-350XLT 4x4, 7.3L, 175K, 3.55, E4OD, Western Pro Plow, AutoMeter Phantom II's, Tymar intake, 3" DPPI D.P. and 3.5" cat delete, 4" single stack kit from Black Cloud, 5"x36" mitre cut S.S. stack from MBRP, Gutted EBPV, Cali FPR, Stancor GPR, 215 Amp Alternator,Custom Battery Cables, SD starter, TS 6 Pos Chip Truck Pics
I've had a couple in the past on other trucks, and they were exactly what I expected. Too good too be true! Overwinding causes them to build up heat fast, real hot in one case, and once hot they dont put out the juice anymore. Not to mention they dont last very long at higher temperatures than they were designed to handle origianally. My .02 anyhow.
Jason
Thanks.No prices on site though, what did you give for yours? I'm having some custom 2/0 wires made up at a local shop here for the entire truck.
Jason
I did that about 2 weeks ago...you will need to change your bolts to longer ones you will also need to change your alt to battery cable I made 2 and ran one to each batterys I also changed my batterys to Gruipe 31 1000 cca you will also need to run a new ground wire to the stud on the altonator from the battery it was easy and the resulates are great 14.6 volts and the other day I forgot to plug her in and it was 7 degrees and it started ..........See battery pix and frame and altonator pix
97 F350 dulie knapheid utility body 7.3 PSD 4x4 8611 LP BLIZZARD plow 8' ss sander diomd plate aulimiumn top boxes ladder rack whalen9004 strobe 6 under cover strobes on board air compressor air ride front and rear spin on trany filter 28 gvw trany cooler w/ fan modified ac condencer as trany cooler down pipe power windows and locks piller gauges piro ,bost ,top shelf incloods air pressure gauge trany temp strobe control, sander control and cb 83000 miles 2004 style headlights clear corners and turns plug in jumpers , grill painted to match truck visor over windshield.5" duel stacks,magnaflow muffler,ss simulators,8 way power leather buckets,2002 dodge console,water filter,5 electric fans,air Horns,215 amp altonator,gruip 31 batteries,tymar intake,5200 lbs rear springs http://community.webshots.com/user/earnies2
I'm pretty sure I have all my bases covered on the install, I'm having custom cables made. My main issue was finding the cheapest price on the 215a. Where did you buy yours? How much?
I checked your photos, nice Mack!!! It's great to see another bulldog fan on here. We currently own 2, an '82 R model and a '93 RB that we fully restored last year. Macks make the best dumptrucks in the world, I wouldnt own anything else.
Jason
Your going to hate me the altonator shop i use for my rebuilds at work I was asking him about the ambulance option and he said (I have one of thoes altonators I'ts been on my shelf forever Take it and see if it fits ) than he said you dont owe me nothing.........What a guy....... i have seen them on EBAY but the best deals are on craigs list I have seen them on craigslist for $125....keep looking their out thier..........If you want I'll ask my alt shop if he has another one and how much it would be........
95 F350 cc, 4x4, 5sp with a short shift kit, 3.55LS, D66 turbo, Beans stage 1's inj, modded ped, IDM mod ,hx mod, DPR intercooler, 3" intakes 3" dp, 4" side out, 2piller w/boost&pyro, steering column mount w/hpop gauge, TW chip, AFE stage 1, ccv mod, DIY oil & coolant filter setups, John Deere coolant eye, ORU RSK, Black Centerline wildcats w/Hankook RT03 315-75-16 mt, One day hope to have a RockDog front bumper w/8" Hellas and a CT performance rear bumper/tire carrier, 05 SD front and rear seats.
Trying to find time to install Con O clutch, 17* HPOP Swamps fuel sys, Ford rear diff cover, Blackbird rear disc brake setup.
I have two Kids and they come first...
(I checked your photos, nice Mack!!! It's great to see another bulldog fan on here. We currently own 2, an '82 R model and a '93 RB that we fully restored last year. Macks make the best dumptrucks in the world, I wouldnt own anything else.)
Jason
thanks for the complement The 27AB is a resent restoration i did. It scored 375 out of 400 points at a Bulldog show and I drove it there. I found it on EBAY last year in arkansasaw It was last running in the 80s and needed a complete rebuild but it was all there .........I fix a fleet of 15 Macks most have ETNYRE asphalt distrubiters on them 4 dumps one sander one drop deck one tractor 2 loaders 4 skid steers one 580 one excaveror and the list goes on oh ya and one 1946 Brockway .........
