Old 07-04-2006, 12:28 PM   #1 (permalink)
Supporting Member
4door96's Avatar
any advice on using nitrous?? *DELETED*
Post deleted by 4door96
1996 f350 2wd dulley, 7.3psd, 190k, 5 speed, 3" down pipe,5" exhaust pipe no restrictions, edge evolution programmer, stage 1 injectors, k&n air, and gauges.
4door96 is offline
Old 07-04-2006, 04:20 PM   #2 (permalink)
Supporting Member
4door96's Avatar
Re: any advice on using nitrous??
no one has anything?
4door96 is offline
Old 07-04-2006, 07:45 PM   #3 (permalink)
You can use nitrous. Diesels love it. Most guys run a two stage system. You can use a big shot of nitrous to it without hurthing anything. With diesels the worse thing you can do is put the fire out and thus stall the engine. So then you just crank it back up.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 07-05-2006, 12:29 AM   #4 (permalink)
Supporting Member
4door96's Avatar
thanks for the advice!! I didnt think anyone wanted to leave me a post.....??
4door96 is offline
Old 07-06-2006, 12:11 AM   #5 (permalink)
ah, the reason why is its in the wrong forum, I'll get a mod to move it to the upgrades and aftermarket forum for you.
Truck pics
Old 07-06-2006, 06:29 AM   #6 (permalink)
Supporting Member
4door96's Avatar
thanks tim
4door96 is offline
Old 07-06-2006, 04:43 PM   #7 (permalink)
Also, you can check out TS Performance's Bye Now nitrous setup to get some ideas. Do you have a one or two stage nitrous setup?
Truck pics
Old 07-06-2006, 04:59 PM   #8 (permalink)
Supporting Member
4door96's Avatar
its only a one stage...but I have 2 solenoids and 2 sprayers one for gas and one for nitrous, I thought I could try making them both work? I've also been thinking about propane since I hear it lasts alot longer than nitrous.
4door96 is offline
Old 07-06-2006, 05:05 PM   #9 (permalink)
If your planning on running drugs, you need to ditch the programer and get a chip tuned for them. Otherwise, it will be like that old Nugent song "Boom, Boom, out go the lights"
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 07-06-2006, 05:08 PM   #10 (permalink)
Supporting Member
4door96's Avatar
since I'm allready having problems with my turbo....maybe I should just leave well enough alone...thanks I didn't know that.
4door96 is offline
Old 07-06-2006, 05:24 PM   #11 (permalink)
The nitrous will be the death of the turbo, the propane would do an imitation of Bill Gates and install windows in your block.
Old 07-06-2006, 05:27 PM   #12 (permalink)
Supporting Member
4door96's Avatar
the turbo is pushing 34 to 36lbs of boost, is there a way to turn it down??
4door96 is offline
Old 07-06-2006, 05:32 PM   #13 (permalink)
HAHAHAHAHA!!!!!! [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Sorry. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
To be back on topic, fuel only is safest. [img]/ubbthreads/images/graemlins/wink.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 07-06-2006, 05:59 PM   #14 (permalink)
Install a wood block on the floorboard underneath the go pedal, this will limit boost, and also get you better fuel mileage. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Put the tuner on the lowest setting, this will help.
Old 07-06-2006, 06:23 PM   #15 (permalink)
Banned
add an intercooler.
lukecline is offline
