Old 12-02-2005, 01:46 PM   #1 (permalink)
Any MODS to improve TCC Lockup??? Want to test!!!!
I'm wondering what mods are around to improve TCC hold. Mine is starting to intermittantly slip after 80k, and there is still no sign of clutch debris in the inline filter or pan. Figure if there is a mod available, I could install and test it to see how much it helps with an already slipping converter before I put a new one in.
Only one I'm aware of is replacing the plastic pump drainback with a steel one. Looking for something that increases TCC lock pressure.
JOAT is offline
Old 12-02-2005, 01:51 PM   #2 (permalink)
Re: Any MODS to improve TCC Lockup??? Want to test!!!!
The best mod I can think of is a speed-sensitve switch that could activate lockup and keep it from cycling in and out above a set speed. Maybe someone could figure out how to build one and help us out [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
richmondfarms is offline
Old 12-02-2005, 01:55 PM   #3 (permalink)
[img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Guess I had that coming [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Really I want to know if a mod will increase holding power. Since it's starting to slip without apparent clutch failure, I would know if the mod helps there.
JOAT is offline
Old 12-02-2005, 06:15 PM   #4 (permalink)
Do you have a chip? I didn't see one in your sig-a chip can increase line pressure, which will help your TC hold. The best mod you could do would be a transgo tugger shift kit. Only thing is you have to pull the front pump to change the spring that increases line pressure. Richter69 likes them, and thats good enough for me. Other than pulling the trans, you will have to go with a transcommand, unless you can find a set of instructions for a b&m shift kit. Mine had some sort of resistor and directions on soldering it in to raise line pressure, but I didn't use it since i have a ts 4-pos. chip. I might be able to find it in my shop. That would be easy for you, anyway.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
Old 12-02-2005, 06:36 PM   #5 (permalink)
My Photos: (5)
transgo kit-pump mods. The raised epc will raise it to a point, then the tcc regulator spring in the pump needs to be replaced.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 12-02-2005, 11:50 PM   #6 (permalink)
Thanks, I used a transgo kit in my ranger A4LD, and it helped alot. Does the higher pressure TCC regulator spring come in the kit? Or is there another source. Didn't see the info on their page. I remember reading about a pump upgrade from someone awhile back but can't remember who it was...
Edit: Found the info I was thinking of HERE. Looks like it's just the drainback checkvalve, tho may be more to it. Guess I need to dig further.
JOAT is offline
Old 12-03-2005, 12:02 AM   #7 (permalink)
My Photos: (5)
that is the sonnax kit, any of the transgo kits will have all the pump parts. The sk kit will be the cheapest.
1999.5 cc dually
Old 12-03-2005, 12:10 AM   #8 (permalink)
Thanks!
I'm probably crazy to pull the tranny to upgrade the pump and not change the converter at the same time, but I just have to try it and see what happens with the slipping. Tranny came out pretty quick last time anyway. Looks like Macko has the Transgo kits, just hope the converter holds up till I can install it. Doesn't seem to slip much yet, just occasionally under a load.
JOAT is offline
Old 12-03-2005, 09:14 AM   #9 (permalink)
The bottom one looks intresting...
http://www.stcperformance.com/autoloc.htm
PS. Not pimp'n the vendor, just something I found. I'm running the top one.
hth,
Jeff Blumenthal
Austin, Tx
97 F350 CC SWD 4X2 4:10, Wildman chip, AFE Stage 2, 6.0 IC, BD 4" Exhaust System, BD Exhaust Brake, BD AutoLoc, Tranny Shift Kitted, Billet Torque Converter, Tru Cool 4739 w/Thremal Bypass, EGT Shutdown Monitor, Air bags, EGT/Boost/Tranny Piller Guages
warpdriv is offline
Old 12-03-2005, 10:49 AM   #10 (permalink)
I've seen those at DIS before. A bit pricey but an interesting product.
JOAT is offline
Old 12-03-2005, 05:56 PM   #11 (permalink)
Old_Machinist's Avatar
I had Jon put in one of his custom torque convertors and the transgo/sonamax kit. So far over a year with babies and a TWildman 4 pos chip and tranny is still going! About to catch up to Tonys record with babies and stock tranny.
Also makes a good time to change out the exhaust donuts on the up pipes. Always had the ideal that if you are going to get into somewhere you might as well do everything you can while you are there!
96 Ford Powerstroke, Centarus Converson CC, 4.10, Long bed DRW, 4 pos TWildman chip, SD HPOP, 6.0 Intercooler, 3.0 downpipe and Bully Dog 4.0 exhaust, AFE intake system, pyro (pre turbo),trans gage (located in test port), Custom Fabion Motosports Torque Converter, pump mods, Tugger trans kit, Torqueshift tranny cooler, Firestone air bags, Rancho RX 9000 adjustable shocks, and baby SWAMPS!!
Pulling a 2000 American Star, 34RLCK bedroom and living room slides, w/d stack ,12,640 lbs.
Total weight 19,300. New addition 20ft VIP Bowrider boat towed behind 5th wheel, total length 74 ft, 24,000 lbs!
Old_Machinist is offline
Old 12-04-2005, 12:06 AM   #12 (permalink)
Thanks for the reminder!
I do have a leaky collector or donut. Didn't even think to get the gaskets to have at the same time. Also perfect time to replace my smashed trans dipstick tube. And rear fuel rail plugs while they'll be easy to get to.
JOAT is offline
Old 12-21-2005, 12:59 PM   #13 (permalink)
Got the shift kit in, what an improvement!
Shifting feels so much smoother now.
Tested the converter clutch slip and it is definitely less now. Tested before pulling to a stop with the TCC mod active and the TCC would slip enough for the engine to hold just under 600 RPM. Now, even with the weakened converter it will pull the RPM down to 500. Wish I'd done this when I replaced the TC originally... Maybe buy me some time on the current one tho, as still no debris in the filters.
Also noticed thanks to a blown fuse ('nother story) that when the tranny is in limp mode the shifts aren't near as harsh as before the Transgo kit. They are hard but not back breaking. Apparently besides giving firmer shifts and more pressure it also regulates the shifts better. I guess the multiple valve springs lets the engagement occur in stages instead of slamming in suddenly.
This is the best $50 (and day of labor) mod I've done to the truck.
JOAT is offline
Old 12-21-2005, 09:36 PM   #14 (permalink)
Hey JOAT, which tranny kit did you install. [img]/ubbthreads/images/graemlins/smile.gif[/img]
-95 F350,PSD,CC,All White,E4OD,- 250 RWHP 560 TQ
-Stage 2 AFE Magnum Force Intake - Custom Flip Chip - Isspro 60 lb. Boost,Scaled Pyro & Tranny Temp in pillar pod - <font color="red">Turbonetics Ball Buster Windmill</font>[img]/ubbthreads/images/graemlins/cool.gif[/img] - Homemade Downpipe - Homemade Reg. Return Fuel System - HPX mod - CCV Mod - Homemade 4" Exaust - 3" Intake Plenums - TransGo HD2 Shift Kit - Soon To Come; Custom I/C - BDP Stage II's - Bigger Oil - Still Looking For that 400+ RWHP!!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
-97 F350,PSD,CC,ZF5SPD. - 3" DP. - LuK Single Mass Flywheel & Clutch. - Isspro 60 lb. Boost & Scaled Pyro in pillar pod.- 100 a/r Non EBPV Turbo - Edge Evolution Race Tuned - 260,xxx Miles And Counting [img]/ubbthreads/images/graemlins/smile.gif[/img]
God,Guns,And Guts Made America. Lets Keep all 3
Gun Control = Using Both Hands!!! &gt;&lt;&gt; &lt;&gt;&lt;
CUR3406B is offline
Old 12-21-2005, 11:48 PM   #15 (permalink)
It was the Transgo SK shift kit, and just the parts for the valve body and pump. No other parts at this time tho I was tempted to go thru it while it was out.
JOAT is offline
