Old 11-03-2006, 12:41 AM   #1 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
Any Pics of a "solid" Dana 50 TTB
ok i know its been done before but i cant find anything about it. im looking for some pics or more info on making a dana 50 TTB a solid axle. thanks [img]/ubbthreads/images/graemlins/cool.gif[/img]
Dan
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille,
318hp 643tq
#24
sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
PSDan000 is online now
Old 11-03-2006, 01:01 AM   #2 (permalink)
rednck21's Avatar
Re: Any Pics of a "solid" Dana 50 TTB
why waste your time...its still a 50 [img]/ubbthreads/images/graemlins/tongue.gif[/img] id like to see this though...
2000 F-250, reg. cab, 4x4, XLT, 7.3, 4R100, built 6/00-forged rods!, DP Tuner F5, AFE stg. 2 w/PG7, MBRP 4", Autometer Ultralight boost/pyro/trans temp gauges, 285 BFG's
2002 Ranger, 3.0 daily driver
73 Bronco Sport - lifted, locked, 331 FI stroker
ECBR
PICS
WEBSHOTS
rednck21 is offline
Old 11-03-2006, 02:45 AM   #3 (permalink)
My Photos: (6)
highfive did it......here's a thread he started with some pics....
solid TTB
'95 XL SuperCab, LWB, 4X4, 204,000 miles, E4OD, 4.10 LS(when it wants to be!), body lift, 305-70-16 Cooper STT's on 10" Eagle Alloy wheels, "Brand X"-inspired home-made open-element air filter, 3" downpipe & 4" straight pipe with 5" stainless tip exiting in front of the rear wheel, 6 pos. TS Performance chip (going to visit T. Wildman soon, I hope), FPR mod, A/C mod, MileMarker manuals, onboard air (York running off the alternator...1 five gallon tank) with dual Grover air horns
2000 Jeep Wrangler Sahara Edition, white w/tan top & interier, 119,000 miles, 4.0L, auto, loaded.....no mods, yet!
Knothead is offline
Old 11-03-2006, 03:19 AM   #4 (permalink)
BlueMule's Avatar
My Photos: (12)
Jon did one for the SwampDonkey years ago.
Ford Twin Traction Beam ( TTB ) Independent Front Suspension ( IFS ) to Straight Axle Conversion
I know of one here locally here in Phx that was converted to a solid axle but he no longer uses it because he now has the balljoint D60 that I was originally going to put under my truck.
And I just recently saw one over on pirate4x4 where the guy used D60 axle shafts.I didnt save the url for that one though so you will have to search the site. There is a whole writeup with pics.
BlueMule is offline
Old 11-03-2006, 06:09 AM   #5 (permalink)
My Photos: (6)
There's a link to Jon's instructions in the thread I referenced, too..... [img]/ubbthreads/images/graemlins/grin.gif[/img]
Knothead is offline
Old 11-03-2006, 06:54 AM   #6 (permalink)
check down in the 7.3 idi forum i know atleast one guy down there that did it. i believe he had a short writeup and some pic's.
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
on the way: more power
bullridin_fool is offline
Old 11-03-2006, 10:45 AM   #7 (permalink)
PSDan000's Avatar
My Photos: (11)
the dana 50 is strong enough i believe, just a PITA when it comes to alignment and ball joints, bushings, etc. i thought maybe this might be an easier/cheaper fix than finding a dana 60, even though thats what i may still do later on.
-Dan
318hp 643tq
#24
My Webshots
Old 11-03-2006, 12:38 PM   #8 (permalink)
PSDfreak's Avatar
Seems some guys have had some good luck converting the D50 to a solid axle...I say if you have the skills to do it and are short on money for a D60 right now (like me [img]/ubbthreads/images/graemlins/grin.gif[/img] ) Go for it! The Dana 50 differential will hold up fine.
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 11-03-2006, 01:11 PM   #9 (permalink)
My Photos: (5)
As far as I know, some of the conversion companies that make econoline 4x4 vans use a solid front axle that is a D50 center.
Does anyone know if there was a D50 front in F250's at some point?
I wonder if that would make a less expensive solid axle swap for our generation of F250???
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 11-03-2006, 02:39 PM   #10 (permalink)
PSDan000's Avatar
My Photos: (11)
quick question, as seen in jon's write up he flipped the rear shackle mounts upside down to gain more lift: http://hometown.aol.com/jzettel73/Resources/24_21A.JPG
anyone know how much lift this will gain? any disadvantages? will i need to weld in a stop block with stock springs? may be a cheaper solution vs. F350 blocks. im seriously considering this solid dana 50 idea. thanks
Dan
-Dan
318hp 643tq
#24
My Webshots
Old 11-03-2006, 03:29 PM   #11 (permalink)
SKY makes a shackle flip for the rear of our trucks. You do have to use tapered blocks though since you are only dropping one end of the spring. The only downside I've heard about is the shackles folding under side load since they were made t o be in tension and are now in compression. This has been reportedly fixed by using pre 99 Super Duty F450 shackles. One person who i casn remember having them was Slope Truck. Iv'e been thinking about the best way of lifting the rear mysel lately.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 11-03-2006, 07:35 PM   #12 (permalink)
rednck21's Avatar
yes all 99-01 F250's used a solid axle 50, but the lug pattern is metric.
ECBR
PICS
WEBSHOTS
rednck21 is offline
Old 11-04-2006, 10:06 AM   #13 (permalink)
johndeerebones's Avatar
AND they have those stupid @$$ 500 dollar unitized wheel bearings.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 11-05-2006, 10:51 PM   #14 (permalink)
The only 50 they might use is the SD style, but I highly doubt it.
Vans are wider than trucks.
The two biggest converters Quigly and Advance 4wd Ssytems (worked there YEARS ago) use custom built 60's.
'95 F250 PSD, Bean 170's, AFE intake, HPC'd 3" downpipe and 3 1/2" cat delete, Magna flow 4" exhaust, DP/Bean 6 pos flip chip with TWildman burns, 6" lift, 35's, 4.10's, ARB frt/rear, custom pre-runner bumper, and some stereo stuff. Daily driven.
'73 Bronco buggy
'06 Jeep Liberty CRD (stock for now)
'90 Miata go-cart
rckcrlr is offline
Old 11-06-2006, 01:21 PM   #15 (permalink)
My Photos: (17)
Dan
Mine's holding up well, just added some homemade bumpstops yesterday but the axle works well. Wish I had a plasma cutter when I did it I would have done the back differently could have made it look more factory.
Kept putting off rotating my new tires and now they have 15k on them, slight cup on the front but not as bad as my straight axle toyota would do in 5k. There's a vendor on ebay that sells the whole drag link tie rod setup for a 92-97 f350 with a straight axle I would buy that package if you do it so you have all new. On the rear shackle flip deal I would get sky's brackets for that and also you can buy their shackles by themselves fairly cheap and they are super stout and you can use them out back(they use them in compression on the front) no way you are gonna roll them over.
1996 F250 Crew Cab 4x4 PSD Mods=
All DIY- E4OD Upgraded DIY Rebuild at 125k, Stroked Injectors, Tymar Style Intake, Exhaust, IDM, DIY RSK with V code SD springs, 1-piece TTB, Big Tranny Cooler and Full Tugger Kit
DP Tuner Chip
Pyro-Tranny-Boost Gauges in Autometer Full Pillar mount
My Truck
highfive is offline
